Thu Dec 19, 2013 10:35 pm
This is how I'm doing it.
/ip upnp
set allow-disable-external-interface=no enabled=yes show-dummy-rule=yes
/ip upnp interfaces
add disabled=no forced-external-ip=xx.xx.xx.xx interface=WAN type=external
add disabled=no interface=LAN1 type=internal
Obviously, Replace x.x.x.x with your external static IP. and the interface values with your real interface names.
Once this is done, Devices can UPNP forward ports. Which you will see under IP>Firewall>NAT with a D next to them for dynamic.
