barkas
Re: RB450G + openwrt Metarouter strange problem
Wed Sep 28, 2011 12:14 am
nope, died on me after 2 hours
QpoX
Wed Sep 28, 2011 2:26 am
Mine did run for 7hours! then the dude told me that is was down, then 2mins later it was up again.
5mins after it came up again, it went down for about 5mins and came up.
And has now been running for 1½ hours with no downtime.
janisk
Wed Sep 28, 2011 8:31 am
no crashes/freezes during the night
timberwolf
Wed Sep 28, 2011 11:09 am
2 Metarouters, just pinging to the host, stable since yesterday 15:00 UTC.
Each Metarouter doesn't show a single loss, max ping rtt 13-14ms.
/metarouter
add disabled=no disk-size=32000kiB memory-size=32MiB name=chaos
add disabled=no disk-size=32000kiB memory-size=32MiB name=chaos2
/metarouter interface
add disabled=no dynamic-bridge=none dynamic-mac-address=02:1B:7E:B1:B7:E2 \
    type=dynamic virtual-machine=chaos vm-mac-address=02:45:5F:D0:20:B1
add disabled=no dynamic-bridge=none dynamic-mac-address=02:52:9C:ED:DC:EF \
    type=dynamic virtual-machine=chaos2 vm-mac-address=02:A7:68:6A:E4:9B
add address=192.168.101.1/24 disabled=no interface=vif1 network=192.168.101.0
add address=192.168.102.1/24 disabled=no interface=vif2 network=192.168.102.0
I will change the setup now, to using an externel ethernet port.
timberwolf
Wed Sep 28, 2011 11:34 am
Conclusion by now: As both barkas and QpoX both have crashes regardless the switch switch-all-ports setting, I think we can rule that out.
Significant difference between my setup and barkas setup is, that my Metarouter does nothing more than just pinging over one interface, and barkas does full MPLS tests.
Janis maybe you could do some MPLS tests between Metarouter and host or some load tests using ipsec? Anything that touches ethernet/ip stacks and/or produces some load...
QpoX
Wed Sep 28, 2011 2:15 pm
Here is my Log:
janisk
Wed Sep 28, 2011 2:19 pm
i have had router with metarouter freeze up without MPLS. I have one suspect that i am testing out, it crashed once without debug MetaROUTER, now router sits at devs with debug version of MetaROUTER. That is thanks to new board that has similar structure as RB450G where debug mode or MetaROUTER can be monitored (it cannot be done or RB450G).
Fingers crossed it crashes again.
some details - Router was just idling same as metarouter, and then it rebooted.
timberwolf
Wed Sep 28, 2011 2:45 pm
Ok, my new Metarouter test crashed after about 3 hours.
Short sketch of the config:
1 Metarouter, 32MB RAM&Disk
2 Virtual Interfaces, one dynamic as bridge port, one static to ether2.
Pinging from Metarouter to host.
Pinging from another System connected at ether2 to Metarouter.
Only things configured in Metarouter where one IP per interface and System name.
Packages:
/system package print
Flags: X - disabled
 #   NAME                    VERSION                    SCHEDULED
 0   routeros-mipsbe         5.6
 1 X ipv6                    5.6
 2   system                  5.6
 3   mpls                    5.6
 4 X hotspot                 5.6
 5 X wireless                5.6
 6   routerboard             5.6
 7   advanced-tools          5.6
 8   security                5.6
 9   ppp                     5.6
10   routing                 5.6
11   dhcp                    5.6
12   ntp                     5.6
Switch all ports ist still set to yes.
I'am sorry, but that is about all I can supply as tests by now.
timberwolf
Wed Sep 28, 2011 3:00 pm
Your devs forgot to include the AR7116 in the JTAG scan chain on the RB450G? ;)
QpoX
Thu Sep 29, 2011 2:00 am
Here is my final log of this test... so it's no working solution...
Now all metarouter interfaces have been disabled again, and it runs stable, but no network to the virtual machines.
timberwolf
Tue Oct 11, 2011 2:46 pm
@MT/janisk:
Any progress to report?
robertpenz
Sat Oct 15, 2011 2:14 pm
I also would be really interested in the progress .....
sigxcpu
Sat Oct 15, 2011 8:31 pm
Unfortunately, who is in charge in solving the problem has no interest :)
janisk
Mon Oct 17, 2011 9:03 am
just stop spamming the forums.
xdemon
Fri Oct 21, 2011 5:05 pm
Any updates about that problem? Reboots for me with metarouter, but works perfectly stable without. RB493G, 5.7
reverged
Sat Oct 22, 2011 12:05 am
Does anyone know if this problem has been seen/reported on RB750GL?
I have, yet again, a useful purpose for a metarouter.
timberwolf
Sat Oct 22, 2011 11:07 am
I guess you only could try yourself, there is extremely less feedback on Metarouters altogether.
And, without wanting to bash MT, there seems to be no clear understanding of the cause on MIPSBE, so every MIPSBE based board should be viewed as affected. Even a small software update might tip those boards over the edge.
sigxcpu
Sun Oct 23, 2011 1:19 am
If people are asking for progress and we don't get any answer, why would you characterize my comments as spam?
@xdemon: I've never reached 24 hours uptime on 750GL with MetaROUTER activated (with OpenWRT guest). I don't know about ROS guest, didn't test. And btw, the VM was doing very light DNS traffic for home LAN.
barkas
Sun Oct 23, 2011 1:45 am
I don't think it's traffic related. I don't really use mine except for testing now and then and it reboots often enough.
janisk
Mon Oct 24, 2011 11:01 am
unfortunately it is all I can disclose. and even then some of info is just a guess :(
so, there are reports of metarouter hanging on RB450G and RB493G. Anyone with RB435G or RB411AH can try metarouter on it?
for me RB433AH does not crash. Now stuck with RB450G that does not reboot :?
timberwolf
Mon Oct 24, 2011 11:19 am
I can only repeat and clarify what I said in earlier posts:
The whole MIPSBE series should be considered unusable in combination with Metarouter.
Especially with the information available from MT and the fact that they aren't capable of fixing this problem in such a long time.
@MT:
This is not intended as pun, just as a warning to everyone planing on using Metarouter on MIPSBE based MT boards.
And don't start repeating that Metarouter is stable on "some" MIPSBE boards, this is just plain luck and might change with every change/release you make.
xdemon
Mon Oct 24, 2011 6:58 pm
It doesn't stable even with routeros virtualized. Crashed after 10 mins with router reboot. metarouter-fs used 40-80% of cpu first 3 mins. I have autosupout.rif file, but i can't find enything useful in it.
UPD: looks like it working after reboot.
timberwolf
Mon Oct 24, 2011 9:43 pm
@xdemon:
Crashes may occur anywhere between 1minute to nearly 1day. The rate increases as you do more work inside the MR.
janisk
Tue Oct 25, 2011 9:54 am
send that supout.rif to support.
reverged
Thu Oct 27, 2011 5:38 am
@MT:
Is this problem isolated to MIPSBE or all BE processors? LE architectures do not have the problem?
If so, those are huge clues.
janisk
Thu Oct 27, 2011 9:46 am
MIPSLE boards do not support metarouter, hence - they do not suffer from this problem. As far as i know various RB4XXG models do suffer from this problem (RB493G, RB450G, RB435G). Never seen this problem on RB433AH and similar.
timberwolf
Thu Oct 27, 2011 11:01 am
@janis:
What he meant where LE architectures in general, not necessarily MIPS-LE, I guess.
And yes, this could have an influence but at a point where it's already to late out of a developers perspective.
janisk
Thu Oct 27, 2011 11:11 am
le, is x86 and mipsle, both of the does not have MetaROUTER.
and this problem is not out of devs perspective. Just there is not a reliable way to reproduce it. As sometimes something starts to happen after 2 weeks other time, restarts happen once in 10 minutes.
reverged
Fri Oct 28, 2011 4:54 am
Yes
Interesting. I did not know le, and in particular x86, doesn't support metarouter! This saves me a hard lesson.
janisk
Fri Oct 28, 2011 9:05 am
on x86 you go KVM to virtualize.
Rivera
Tue Nov 01, 2011 4:28 pm
Can anyone run 'while true;do dmesg -c;done' and see what happens? And please leave that command running in openwrt (for example in background)
Rivera
Tue Nov 01, 2011 4:48 pm
And yes, there is something i discovered in process of testing:
1) netconsole. There is no error logs sent via network - only standart boot data.
2) There is no crashdumps in openwrt machine. Basically everything is okay with openwrt.
3) i tried watching dmesg, and there is no error messages too.
4) Mikrotik MetaRouter (with RouterOS machine) sometimes hangs too.
5) And... sometimes reboots of router (physical, not virtual one)
So... this is 100% RouterOS fault. I sent supout file to mikrotik.
P.S. if we only had access to more verbose logs...
barkas
Tue Nov 01, 2011 5:03 pm
But we don't, because the machine crashes hard.
Rivera
Fri Nov 11, 2011 3:31 pm
v 5.8, still broken. Also crashes host machine.
Rivera
Fri Nov 11, 2011 9:47 pm
Some interesting info. I enabled writing debug logs to disk, and tried to catch some messages.
Of course i haven't found any useful info, but...
There were no virtual machine freezes
Instead, router crashes hard. I always saw that first virtual machine freezes, and then router crashes (if you do not disable VM via /metarouter _before_ router crashes - if you will be fast and disable VM router will not crash)
I tried that, well, somewhere around 10 times. VM _do not freeze_. Router crashes anyway...
Maybe that somehow related to filesystem?
rviteri
Fri Nov 18, 2011 5:56 pm
I am just using metarouter so I can load OpenVPN into OpenWRT to use UDP as the transport protocol. If MT could just add the UDP option for OpenVPN instead of only TCP I bet it would solve some problems out there.
mitjax
Thu Dec 29, 2011 1:07 pm
Any news on this RB450G + Metarouter + OpenWRT problem?
I am running RB450G v5.11 and still the board crashes.
Mikrotik?
timberwolf
Tue Jan 03, 2012 6:44 pm
I wouldn't hold my breath.
Maybe a x86 Board like Soekris net6501 with KVM will be more usable; I didn't try.
I just use MikroTik/ROS for testing and home usage and gave up all planned and realized productive installations.
alafangla
Tue Jan 17, 2012 11:39 pm
unfortunately, we already paid for mikrotik board, so why are you wondering about no support...? :(
this isn`t good way to atract new customers, shame on you MT. i bought RB450G, it was my first and last product from you.
elgo
Wed Jan 18, 2012 11:38 am
I couldn't agree more :?
Iliasla
Thu Feb 02, 2012 6:08 am
Perhaps the problem is really in miscalculations in the design of power converters on the routerboard 450G. With a standard external power supply DVE DSA-20P-20 24V/0.8A router, when running metarouter, was unstable and often restart at arbitrary times, even in idle mode. ROS 3x, 4x, 5x - no difference. However, with the simple old transformer power supply 12V/0.5A router works fine for more than a day, with a test load in the form of Ping Speed between the router and metarouter (average 163 Mbps at a reduced up to 400 MHz cpu clock).
By the way, lowering the CPU clock from 680 MHz to 400 MHz did not affect the instability.
When using low voltage power supply, became less warm coils and capacitors in both the power converters to 3.3V on routerboard, which is an indirect proof of engineering miscalculation. And stronger heated coil, which supplies the switch chip and memory. In this scheme fits the fact, that router is a bit more stable in the mode "switch-all-ports=no".
IMHO, the designers of this model were to use a more powerful power converter, similar to that used in RB433x.
Another is the idea of replacing the electrolytic capacitors on the solid polymer capacitors. It is not excluded, that this may also solve the problem.
ps Forgive me my nice Google English :)
janisk
Thu Feb 02, 2012 9:51 am
the frequency of reboots of the board is not connected to PSU in any way, of course, board has to have enough resources. It was tested at full CPU load.
peson
Trainer
Trainer
Thu Feb 02, 2012 10:42 am
It's not just the MIPSBE, I have the same behavior with PPC platform, RB1000 and RB1100AH tested.
My bet is that the MetaROUTER software is unstable.
Have anyone configured the guest interfaces in dynamic mode only?
I'm wondering if the setup of static interfaces is not correctly configured in the underlaying Linux kernel.
I was convinced that static interfaces is a HW bypass directly to the guest, but I don't think so any more.
janisk
Fri Feb 03, 2012 8:36 am
what configuration you have? All problems about MR on PPC routers was resolved by adjusting configuration
peson
Trainer
Trainer
Fri Feb 03, 2012 9:27 am
I have a support ticket that you are familiar with.
/Paul
reverged
Sat Feb 04, 2012 10:16 pm
Can you elaborate on this? What specific configuration changes resolve MR issues on PPC routers?
Is there a wiki of sorts?
I had given up on Metarouter until mipsbe becomes stable. But if ppc is stable....
I'm installing an RB1100AH next week and could use MR for lots of things - if ppc Metrouter is stable.
timberwolf
Sat Feb 04, 2012 11:43 pm
:D Just don't configure anything and everything will be almost fine. :lol:
peson
Trainer
Trainer
Mon Feb 06, 2012 11:20 am
Timberwolf, so your opinion is not to use MR at all, at least not until a stable version is available? ;)
timberwolf
Mon Feb 06, 2012 11:32 am
Yes, that is exactly my opinion.
And my impression is, that this will be never.
peson
Trainer
Trainer
Mon Feb 06, 2012 11:46 am
So, your saying MR in general on all platforms including PPC platform?
And you're not agree on the statement? :
http://forum.mikrotik.com/viewtopic.php ... 11#p301963
Do you have any experience of ROS x86 KVM stability?
timberwolf
Mon Feb 06, 2012 12:27 pm
Tweaking your configuration until the system runs stable isn't a solution.
At best that's a workarround and nothing you let your customers play with.
No. I would like to think that this configuration might be usable, but I am unwilling to take the risk.
I'm starting to suspect that whoever wrote the MR code isn't longer working for MikroTik. So MR might be considered an abandoned technology.
peson
Trainer
Trainer
Mon Feb 06, 2012 1:16 pm
Totally agree on this.
As long there aren't any description and manuals provided with confirmed and tested configurations, the MR aren't usefull.
I will setup an x86 appliance for heavy tests the KVM.
I'm going to test it exactly same way as I'm testing the MR
janisk
Tue Feb 07, 2012 9:22 am
good, waiting for your results.
peson
Trainer
Trainer
Wed Feb 08, 2012 5:50 pm
Some results, or to be more precise, different config settings between MetaROUTER and KVM.
Janis! correct me if I'm wrong about my assumptions and conclusions.
I'm trying to understand the different configurations based on my Linux knowledge and how-to configuring tun/tap, vlan and bridges in Linux OS.
When creating static interfaces in MetaROUTER, you can select physical interfaces like Ether1.
The selection list on KVM show only the interfaces already added as Virtual Ethernet interfaces. (/interface virtual-ethernet)
In MR, if I use a physical (not configured on the host) interface in a guest and add VLAN on that interface on the guest, the VLANs works.
To do the same thing in KVM I need to create a bridge with a tap interface and the physical interface I want to bind it to.
The tap interface is the interface that is attached to the guest.
If I create the same configuration in MR with a bridge between a physical and virtual and the vif attached to the guest, all interfaces stops responding.
I have arp in the guest and the bridge host table looks alright, but the guest is not responding.
The difference between the configuration of virtual ethernet interfaces, is that in KVM you can assign MAC-address on both host and guest side, but not in MR.
If I, in MR, change from static to dynamic and assign the interface to the same bridge it all starts working again. And now, it assigns a MAC-address on the host side.
From Winbox (2.2.18) I can add and view Virtual Ethernet interfaces in KVM, but not in MR.
Is the MetaROUTER paravirtualization or just a software on the hosts that emulates a ROS?
More to come.....
janisk
Thu Feb 09, 2012 10:00 am
this one is interesting, now if you could give full configuration of the "same" configuration would be nice (to avoid confusions. That is mipsbe router?)
when you assign physical interface to MR tap interface is tapped into the physical interface well before a lot of stuff that works with packets in RouterOS. There are some services that can get packets on the host from that interface, but could not work around that. In KVM that is not possible. When transmit happens from MR packets are put into interface send buffer and interface just sends them out (as it usually does, as interface only concern is OSI Layer1)
MetaROUTER is not just ROS emulation, as it is possible to have OpenWRT and, as some reports say, debian running as guests. Similar to KVM, MR requires CPU virtualization support.
RouterBOARD routers will not have Virtual Ethernet tab, instead use filtering to filter out virtual interfaces if you have a lot of interfaces on the router.
Iliasla
Mon Feb 13, 2012 8:21 am
Maybe ... However, with a 12 volt transformer PSU 450G uptime for over 5 days. However, I did not banished tests this time, but with a 24 volt PSU uptime does not exceed several hours even under no load.
janisk
Mon Feb 13, 2012 9:11 am
i have ability to set PSU voltage to value i desire in range where RB450G is working and change of that did not change stability of the setup. Maybe you could list what amperage you get at what voltage from these PSUs?
edit: check in what condition are your capacitors.
barkas
Wed Feb 15, 2012 4:10 pm
OpenWRT is heavily patched to run on MetaRouter. I seriously doubt you can get anything to run without heavy modifications, e.g. full paravirtualization.
Are you sure MetaRouter does hardware virtualization on MIPS?
timberwolf
Wed Feb 15, 2012 5:15 pm
I wonder, if by any chance, one of the MetaRouter developers could chime in here and contribute something usefull or at least interesting...
Iliasla
Wed Feb 15, 2012 6:28 pm
janisk
Transformer PSU used DVE DV-1250UP 12V/0.5A
450G when operating this PSU at idle consumes 0.36A with running Metarouter and 0.31A with a stopped Metarouter
The problem with the electrolitic capacitors Suxxon me know :) see here and here. These capacitors from the main DC/DC converter (7...28V to 3.3V) were replaced in advance by electrolitic Nichicon 1000.0/6.3V, combined with a faulty motherboard. The input capacitor 330.0/35V I have not replaced, he works in a relatively comfortable conditions.
In the plans to test the stability of pulsed PSU Powertron PA1008-2DE 12V/0.5A. And how will his free time, to measure the waveform at several control points on the power rails. It also plans after checking power supplies want to replace electrolytic capacitors with polymeric and verify with the standard 24V PSU.
p.s. There is also a possibility that could fail PoE switch logic, such as short-term switch, which is why just lost power. Unfortunately, I have no design scheme to say this objectively.
janisk
Thu Feb 16, 2012 9:52 am
all questions are delivered to MetaROUTER devs
rviteri
Sat Feb 18, 2012 4:15 am
So will this ever be fixed at all?
Iliasla
Thu Feb 23, 2012 8:12 am
Stability test with a pulse PSU Powertron PA1008-2DE 12V/0.5A is successful. RB450G uptime 5 days.
janisk
Thu Feb 23, 2012 8:59 am
with all links active and with CPU loaded 0.5A @12V can be too short. You could be lucky with any other PSU. But good to hear that you have it running for 5 days now.
Iliasla
Thu Feb 23, 2012 3:46 pm
No, only four active link and a regular on an Internet surfing. But even in this mode with 24V PSU uptime does not exceed several hours.
"Native" 24V PSU tried two things - with both equally unstable.
p.s. It is still checking PSU. Ahead - a study with an oscilloscope. ))
rviteri
Fri Feb 24, 2012 1:43 pm
Really, oscilloscope? End result. The feature seems to just not work.
janisk
Mon Feb 27, 2012 4:17 pm
or id having just system and security packages it works for very long times (sometimes)
Begetan
Thu Mar 22, 2012 11:10 am
Today I began to test Metarouter on RB493G platform, ROS5.12
I'm runing defult configuration on host router and two MR - one with ROS 5.12, the other with DDWRT images from this manual http://wiki.mikrotik.com/wiki/Manual:Metarouter.
Every router has one static and one dynamic port. Thats all.
I'v got 3 crashes ( with systems reboot) with interval from 15 to 90 minutes.
I see that RB45x and RB49x devices not sutable for MR feature about 3 years :shock:
Could anybody answere below question?
1. Does this problem deal with only DDWRT or ROS Virtual machine too?
2. How it works on PPC architecture?
3. What device is the most stable for runing MR wit ROS Image? How long uptime they have?
peson
Trainer
Trainer
Thu Mar 22, 2012 12:22 pm
As you can read from my previous posts, the MR aren't useful in any platform.
If you want virtualization in ROS, go for x86 platform and run KVM (Qemu) guests.
/Paul
rviteri
Mon Jul 02, 2012 6:48 pm
Did this ever get solved? Or all is lost?
timberwolf
Mon Jul 02, 2012 9:12 pm
MT claims to be close to a fix, have a look here: http://forum.mikrotik.com/viewtopic.php?f=15&t=60746
rviteri
Thu Jul 05, 2012 7:07 am
Doesn't look like it to me..
Users browsing this forum: No registered users and 19 guests
