• MikroTik.com
  • RouterBOARD
  • User Meeting
  • Training
  • User Manual
  • Support
  • Downloads
  • Videos
Register |   * Login | HOME
View unanswered posts | View active topics
MetaRouter is causing high loads  Page 1 of 1
 [ 2 posts ]  Post new topic Reply to topic
  Print view Previous topic | Next topic
Author Message
bakkerl
 Post subject: MetaRouter is causing high loads
PostPosted: Fri Jan 15, 2010 12:12 am
Offline
I have a setup like attached to this post.
From left to right:
- line is my internet uplink
- RB1000 [1] is my first RB1000 device
- next line is a (utp) connection between the two RB1000 devices.
- the right RB1000 [2] had a bridge group with a ether1
- On the right RB1000 [2] there is a MetaRouter (connected to the bridge by a vif)
- The meta router is connected to ether2
- Ether2 is connected to a host machine by utp.
Nothing strange so far.
If there is a 'large' file transfer, and the connected speed between the internet and the host machine will go over 10Mbit/s, the MetaRouter cpu load is going up above 40. The load on the second RB1000 [2] is also going up with the same amount (logical). The load on the first RB1000 [1] is stable between 1 and 3% cpu load. Both RB1000 and the metarouters are only setup to forward this traffic, and no filtering or logging is done on these routers.
I know that a 100% cpu load automatically means that it hasn't no more capacity to route the traffic normally, but why is load in the Metarouter at 40% cpu and on the other fysical RB1000 still at 1-3% cpu load?
And can i see what is causing this load?
Top
 Profile
janisk
 Post subject: Re: MetaRouter is causing high loads
PostPosted: Fri Jan 15, 2010 9:04 am
Offline
this is how metarouter works. Load is caused by metarouter handling packets. initial CPU hit is high, but you can push reasonable amount of packets through due to a way packets are handled by RouterOS.
Top
 Profile
Display posts from previous:  Sort by
Post new topic Reply to topic  Page 1 of 1
 [ 2 posts ]
Board index » RouterOS » Virtualization
Users browsing this forum: No registered users and 2 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB® Forum Software © phpBB Group
Karma functions powered by Karma MOD © 2007, 2009 m157y
