RexY
Cannot detect ethernet adapter on windows guestOS
Thu Dec 01, 2011 10:54 am
Hi, is there anyone find that we can't use the ethernet adapter on windows guestOS.. because of this, the windows guestOS can't connect to the router.. I didn't found these problem on Linux guestOS.. :(
is there any solution for the problem ? thanks by the way :)
janisk
Re: Cannot detect ethernet adapter on windows guestOS
Thu Dec 01, 2011 2:17 pm
if you run this as a KVM guest, then try to set different interface type on the host for this guest. it seems windows dislikes virtio interface (the default).
RexY
Tue Dec 13, 2011 10:24 am
hi, thanks for the clue.. I tried change it with e1000 and PCnet. seems that the guestOS still can't read the ethernet controller.. :(
or maybe can I use a guest driver that I found on KVM for linux ??
seems like a dead end here.. :?
janisk
Tue Dec 13, 2011 12:58 pm
e1000 card works with RouterOS. Citrix has to something different to render the problem.
Users browsing this forum: No registered users and 14 guests
