Thu Apr 24, 2014 10:02 am
we have serious problem with RB260:
we are using RB260 with singlemode 1-fibre SFP modules (1310, 1550nm) GigaLight GPB-3524L-L2CD-C (cisco compatible) "blue"
and another end of fibre is
EDGECORE ES4624-SFP or SIGNAMAX 065-7851 or brocade FCX624S-F or mikrotik
or RB2011xxxx with "yellow" GPB-5324L-L2CD-C
EDIT: now tested also with Mikrotik S-53LC20D (blue) and S53LC20D (yellow) and WE HAVE THE SAME RESULTS - after power disconnect+reconnect SFP is unable to connect without SFP module unplug + replug
problem is SFP initialization after SHORT power failure or FAST DISCONNECT/RECONNECT power adapter on RB260 - ethernet ports are working,
but in switch management is SFP module not visible
after unplug and plug SFP works normally, problem problem is with SFP initialization / handling on RB260?!
tested also 1-fibre SPB-7710CIS-HTR - SPB-7610CIS-HTR and working correctly ...?!
2-fibre SFPs are working normally, so problem is with 1-fibre SFP handling/negotiation/initialization?? ...
CAN U PLEASE MAKE FIX FOR THIS BUG????!!!
