As I try to traceroute to cloud.mikrotik.com, the trace won't go to the host, and this is at least from two different directions (that is, my routers are at al least two different ISP, these ISPs are using different uplinks so the directions to your hosts are different, too).
Here is the first trace (I drop "my" hosts from the listing):
Here is the second trace:1 - skip -
2 109.239.209.41 0% 1 1.1ms 1.1 1.1 1.1
3 188.254.100.133 0% 1 0.9ms 0.9 0.9 0.9
4 95.167.93.150 0% 1 35.6ms 35.6 35.6 35.6
5 92.50.199.30 0% 1 46.7ms 46.7 46.7 46.7
6 195.122.0.213 0% 1 45.3ms 45.3 45.3 45.3
7 100% 1 timeout
8 100% 1 timeout
Here is another trace:1 83.219.128.0 0% 1 1.5ms 1.5 1.5 1.5
2 10.192.168.145 0% 1 1.5ms 1.5 1.5 1.5
3 10.192.168.255 0% 1 8.3ms 8.3 8.3 8.3
4 91.90.249.130 0% 1 8.3ms 8.3 8.3 8.3
5 195.246.227.8 0% 1 8.3ms 8.3 8.3 8.3
6 89.201.51.214 0% 1 8.8ms 8.8 8.8 8.8
7 100% 1 timeout
8 100% 1 timeout
Another trace:1 - skip -
2 79.104.235.78 0% 2 58ms 58 58 58
3 213.221.4.132 0% 2 57.5ms 58.6 57.5 59.7
4 195.122.0.213 0% 2 69.1ms 68.5 67.9 69.1
5 100% 2 timeout
6 100% 1 timeout
195.122.0.213 looks like the most often 'last' hope.1 - skip -
2 217.16.23.138 0% 1 97.2ms 97.2 97.2 97.2 0
3 193.232.245.156 0% 1 22.2ms 22.2 22.2 22.2 0
4 195.122.0.213 0% 1 23.1ms 23.1 23.1 23.1 0
5 100% 1 timeout
6 100% 1 timeout
The problem is there for about 30 hours so far. Is there any chance to see the cloud system running soon, and should we rely on cloud feature in the future?
P.S. Just in case, do you have any availability checks of your "cloud" system from around the world?
