manuelm
Ether4 amber light stays ON and failed login attempts
Mon Feb 20, 2017 10:41 pm
Hi Everyone,
Have you ever seen the light on one of the ports stay on even though there is no cable connected to this port. I upgraded the firmware and restarted\unplugged the router, but the light doesn't go away. What's causing this?
I'm also getting alerts from failed login attempts via local. There is nothing connected to the serial port, so I'm not sure what's producing these logs.
[img]logs.PNG[/img]
[blank@blank] >
12:35:31 echo: system,error,critical login failure for user \80\C0\C0\C0\E0\C0\C0\E0\F0\F0\E0\E0\C0\82\F0\F0\E0\E0\C0\E0\C0\C0\C0\F2\F0\C0\C2\F0\E0\E0\F0\E0\C0\C0\F0\F0\E2\E0\E2\C0\F0\F0\C0\C0\C0\E0\E2\80\F0\E2\F0\F0\F2\F0\E0\80\C0\C0\F0\C1\E0\F0\E0\E0
\E2\F0\E0\80\C0\C0\C1\C0\C0\C0\C0\C0\C1\E0\C0\E0\C1\81\E0\F0\C0\C0\81\E2\E2\C0\F0\E0\F0\E0\C0\80\C0\F0\F0\F0\F0\E0\F8\F2\F0\81\C0\C2\E1\E3\F2\F0\F0\F0\E0\E2\C0\C0\C0\E0\C0\E2\F0\E0\F0\F1\F0\E0 via local
[blank@Adante] >
12:35:45 echo: system,error,critical login failure for user \E0\E0\80\C0\E0\C3\C3\E1\E0\81\C0\E0\F0\F2\E1\E0\E0\E0\E0\83\C0\E0\C2\C0\C0\C0\C1\C2\C0\C3\E1\E0\C0\C0\FC\C0\E2\C0\F0\F8\F8\F0\E0\C1\F0\F8\F0\F8\E2\E0\E0\FA\F8\F0\F0\F2\E0\F0\F8\F0\E2\F8\E0\C0
\C0\FA\E0\F8\E0\C0\F8\C0\F8\F0\E0\C0\F0\E5\F1\F2\F8\F0\F0\F0\F0\C0\E0\C0\D2\F8\F0\F0\F8\F0\F0\E0\E2\F0\F0\E0\E0\E0\C0\F0\C0\E0\C0\C2\C0\E0\F0\F0\E0\E0\E0\C2\C0\F0\C1\E0\E0\E0\C0\F0\C0\82\C0\C1 via local
[blank@Adante] >
12:35:48 echo: system,error,critical login failure for user \81\E1\E2\C0\F0\C0\C2\C0\E0\F0\E0\C0\E0\C2\F2\F2\F8\E2\E0\FA\F8\F8\F2\E0\C0\C8\FA\F0\F8\E2\F8\C0\FA\F8\F2\FA\F8\C0\F0\C0\FC\F0\F0\F2\C0\E0\FA\E3\F8\C0\C0\F2\C0\F0\E0\F8\F8\89\F2\E0\F8\F8\F2\F0
\F0\C0\C0\C0\CA\F8\F0\FA\F2\F8\F8\F2\81\C2\C1\89\FA\F8\F0\F2\F8\E0\E2\E0\C2\E1\E0\C2\82\C0\E0\C0\C0\C0\82\E0\E1\C0\83\83\C8\E0\F0\C1\C0\C0\F8\F8\F0\F0\F8\E2\F0\80\C0\E0\C3\F0\F8\F8\F2\F2\F0\F8 via local
[blank@Adante] >
12:35:49 echo: system,error,critical login failure for user \E0\E0\C1\C0\E0\C1\C2\C2\C0\E0\81\C0\80\C0\C0\C1\C1\E0\E0\82\C0\E1\C0\E0\C0\C0\81\C0\E0\E3\C0\E0\E0\C1\E2\E0\C0\C0\C1\C2\C0\80\C0\C0\C0\C1\E0\F8\C0\C1\E0\E0\E0\F0\F0\C0\E1\F2\E2\E0\F0\F0\81\C0
\F0\F0\F0\F0\E2\C0\F8\F0\F0\F0\F8\83\C2\C0\C0\E0\F0\C0\E0\80\81\C0\C0\C0\C0\E0\F0\E0\C2\C0\E2\C0\C0\C0\C0\C2\C0\81\C0\C0\E0\E0\C1\E0\80\C0\E0 via local
[user133@Adante] >
12:36:00 echo: system,error,critical login failure for user \E0\C1\E0\C2\E0\E0\E0\C0\C0\E1\C1\82\E2\C0\E3\E2\E2\C0\C0\F2\F0\F8\F0\F0\C0\E0\F9\F0\F0\F0\F0\C0\80\C0\F0\C0\E0\E0\E0\80\E0\E3\F0\E2\C0\C0\F8\F0\F1\E2\C0\F2\E0\C0\F0\C3\80\F8\F2\F2\F0\F0\E0\E0
\E2\80\C0\C0\C0\C0\F8\E2\F0\F0\E2\E2\F0\C0\03\E0\82\C0\C0\E1\E2\F0\F0\F0\F0\F0\E2\C0\C0\C0\88\F0\F0\F0\F8\F1\F2\F8\C1\C0\E0\C2\F2\F8\F0\F0\F2\F2\F0\80\C1\C0\83\81\F0\F0\F0\F0\E2\E0\F0\C1\C0\C0 via local
[blank@Adante] >
12:36:39 echo: system,error,critical login failure for user \C2\F0\E0\E1\82\C0\80\C0\E0\80\C0\C0\C1\C0\C1\C1\C1\C2\C0\C1\80\E0\E1\C2\80\F2\F2\F0\F1\F0\C0\81\F0\F0\F0\F2\F0\C0\01\F0\F0\F0\E0\E0\C0\F0\F1\F0\F2\F0\C0\C0\F2\E3\F2\F0\E0\80\C0\F0\F2\82\F8\F1
\C2\F0\F0\C1\E2\F2\F0\F8\F0\E0\F8\F2\80\80\E0\C9\F0\F0\F0\E2\E0\F2\F0\C0\C0\C0\C1\F2\F0\C0\F0\F0\F0\E2\E0\C1\C0\C0\F8\F0\F2\8B\E0\C0\E0\C0\E0\C0\C0\E0\E0\E0\C0\C2\E0\C2\C1\E2\E0\C1\E0\C0\E1\E0 via local
[blank@Adante] >
12:36:40 echo: system,error,critical login failure for user \C0\C0\C0\E0\E0\C0\80\80\80\80\80\03\C0\E0\E0\C0\80\E0\F0\C0\E0\E0\81\E0\C1\E0\E0\F0\E0\C0\F0\E0\C0\E0\E0 via local
Users browsing this forum: marcelbohmer, regisc, sas2k and 122 guests
