Hello.
I'am looking for a cheap managed Switch with 8x POE/POE+ gigabit ports to use it with mikrotik and Voipphones. Anyone has a hint which one i can use ? I does not need to be from mikrotik, as i have not found any product that fits that specifications. The problem is, that many switches are so expensive that the advantage of the POE gets burned by the price, if you just want to use them, because you don't want to use a separate power supply for the phones.
thanks for help.
