• MikroTik.com
  • RouterBOARD
  • User Meeting
  • Training
  • User Manual
  • Support
  • Downloads
  • Videos
Register |   * Login | HOME
View unanswered posts | View active topics
Winbox running on Windows Vista  Page 1 of 1
 [ 21 posts ]  Post new topic Reply to topic
  Print view Previous topic | Next topic
Author Message
keithb1978
 Post subject: Winbox running on Windows Vista
PostPosted: Fri May 11, 2007 9:35 pm
Offline
Hi there all.
Was wondering if someone has found a solution to get the history and the save sites facility in Winbox to store those addresses in Vista. everytime I open winbox it has cleared all the addresses. I also cannot do a MAC scan in vista always comes up blank.
Have tried to run the app as a administrator and set it to run in compatiblilty mode but have had no joy
Keith
Top
 Profile
csickles
 Post subject:
PostPosted: Fri May 11, 2007 9:43 pm
Offline
I dont know about the history...
But vista has an inbound and outbound firewall.. well um ahh I ,,, um....
You will probably need to open a rule for winbox and / or it's ports..
Craig
_________________
Things that make you go "Hmmmmmmmm"...
Craig
Top
 Profile
keithb1978
 Post subject:
PostPosted: Fri May 11, 2007 9:58 pm
Offline
Craig
I have opened the ports for winbox - I can connect to sites but having 28 RB high sites it was usefull to save the IP address and login details in winbox.
Could I be missing some ports for the MAC search?
Top
 Profile
mrz
 Post subject:
PostPosted: Fri May 11, 2007 10:00 pm
Offline
1. Disable that crappy windows firewall.
2. Turn off UAC
3. Disable defender ( this crap isn't doing anything anyway ).
Top
 Profile
normis
 Post subject:
PostPosted: Mon May 14, 2007 7:59 am
Offline
I'm using Vista and I don't have this problem. Either try to do what mrz said, or you might have some other problem
Top
 Profile
Binayak
 Post subject:
PostPosted: Thu May 17, 2007 10:56 pm
Offline
i too am using vista ... and dont have any such problem.
Top
 Profile
Ghassan
 Post subject:
PostPosted: Fri May 18, 2007 12:48 am
Offline
me too i have tried using winbox on windows vista but Windows vista has a great firewall locally and over the network .
Top
 Profile
stealthwave
 Post subject:
PostPosted: Fri May 18, 2007 7:05 am
Offline
I am running crappy Vista and do not have any problems with winbox.
I think its just Keithb has a direct short on his key board. LOL
I guess you got your new laptops.
Top
 Profile
MikroManagement
 Post subject: Re: Winbox running on Windows Vista
PostPosted: Wed Jun 20, 2007 7:01 pm
Offline
My defender and firewall disabled - still the same issue.
Will try UAC just now, but the "Run as Administrator" feature didn't work either
Top
 Profile
MikroManagement
PostPosted: Wed Jun 20, 2007 7:26 pm
Offline
nope... still not functioning. Not UAC, defender or firewall. must be something else
It worked on my old notebook, also running Vista Ultimate.
Any other ideas?
Top
 Profile
mrz
PostPosted: Wed Jun 20, 2007 7:45 pm
Offline
Then check if you have plugged in ethernet cable :))
Top
 Profile
dsovereen
PostPosted: Thu Jun 21, 2007 3:07 pm
Offline
My Winbox just lost all of its saved sites. When I re-import from a saved list, everything is there. But when I close Winbox and re-open, everything is blank again.
Also, Winbox has to download all plugins every time.
Mikrotik: where does Winbox look to find its saved config?
There is a folder at c:\Users\dsovereen.CONTROLLER\AppData\Roaming\Mikrotik\Winbox that has as config file of all the saved systems and all of the downloaded plugins, but Winbox doesn't seem to see it anymore.
Dave
Top
 Profile
MikroManagement
PostPosted: Thu Jun 21, 2007 6:13 pm
Offline
I'm on wireless... No ethernet cables required
And yes, my Winbox also downloads several files
Still no solution this side.
Top
 Profile
MikroManagement
PostPosted: Thu Jun 21, 2007 6:19 pm
Offline
it actually worked on a previous version of vista
Pretty sure that it has something to do with the %APPDATA% variable.
I've deleted my MikroTik folder, and it doesn't recreate it - either not used anymore or no access
Top
 Profile
mrz
PostPosted: Thu Jun 21, 2007 6:40 pm
Offline
probably you have changed something in system variables.
Winbox config is located here by default:
C:\Users\<username>\AppData\Roaming\Mikrotik\Winbox
Top
 Profile
dsovereen
PostPosted: Thu Jun 21, 2007 6:50 pm
Offline
That's exactly where my Mikrotik stuff is:
C:\Users\dsovereen.CONTROLLER\AppData\Roaming\Mikrotik\Winbox
But Winbox doesn't use the files there anymore. They are there. Winbox just doesn't seem to see them.
I wish Mikrotik would diagnose this so that I could either correct Vista or they could adjust Winbox so it worked.
Dave
Top
 Profile
mrz
PostPosted: Thu Jun 21, 2007 7:02 pm
Offline
open registry editor:
Computer\HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folder
and make sure that AppData is set to "C:\Users\<user>\AppData\Roaming"
Computer\HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folder
AppData should be "%USERPROFILE%\AppData\Roaming"
Computer\HKEY_CURRENT_USER\Volatile Environment
AppData ishould be "C:\Users\<user>\AppData\Roaming"
Top
 Profile
dsovereen
PostPosted: Thu Jun 21, 2007 7:31 pm
Offline
My first one was C:\Documents and Settings\ReleaseEngineer.MACROVISION\Application Data and several others were C:\Documents and Settings\ReleaseEngineer.MACROVISION... Went to Macrovision's web site. They deal in digital rights management... I think it was software I had to download in order to buy some MP3s. Walmart is the only MP-3 download store I've used on this computer. I uninstalled the software but it didn't change the registry entries back.
I deleted all of the entries that had C:\Documents and Settings\ReleaseEngineer.MACROVISION in them (looks like they default correctly when automatically re-added) and Winbox is good again.
THANK YOU!
Dave
Top
 Profile
MikroManagement
PostPosted: Thu Jun 21, 2007 10:46 pm
Offline
Perfect!! Thank you, I'm back online as well
Top
 Profile
nikhil
PostPosted: Tue Nov 20, 2007 11:10 pm
Offline
Same problem with mine, registry changed to Macrovision . Changing that solved the problem. Hope this thread helps other Vista users .
Top
 Profile
R1CH
PostPosted: Thu Nov 22, 2007 1:18 am
Offline
Remember to complain to the supplier of the software about how the DRM breaks your registry settings. Big corporations keep trying to push DRM out but when it has nasty side effects like this, it just isn't acceptable!
Top
 Profile
Display posts from previous:  Sort by
Post new topic Reply to topic  Page 1 of 1
 [ 21 posts ]
Board index » RouterOS » General
Users browsing this forum: drvirus, Google [Bot] and 22 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB® Forum Software © phpBB Group
Karma functions powered by Karma MOD © 2007, 2009 m157y
