fuzzytech
Difference between IP PROXY and IP WEB-PROXY
Fri Jun 15, 2007 7:13 am
Does anyone can explain the differences between IP PROXY and IP WEB-PROXY?
How can i configure them? what happen if i enabling both of the service?
Regards,
FZT
normis
Re: Difference between IP PROXY and IP WEB-PROXY
Fri Jun 15, 2007 9:44 am
use only one. webproxy is old and based on squid, which has bugs. ip proxy is new, made by mikrotik, and will eventually replace webproxy. it is also faster and will have more features.
Gerlach76
Fri Jun 15, 2007 1:56 pm
Is it possibly to run ip-proxy in transparent mode?
And how i can secure my proxy please post an example.
THX
ram
Sun Jun 17, 2007 11:41 am
hi ..does the ip proxy support cache like web proxy?if yes then how... I haven't seen cache setting in ip proxy!
normis
Tue Jun 19, 2007 10:13 am
what ROS version do you use?
wikram
Tue Jun 19, 2007 5:23 pm
please can u tell me how to block sites using ip proxy . can u plz specify the command to block a site eg http://www.hotmail.com
normis
Wed Jun 20, 2007 12:15 pm
wikram
Sun Jun 24, 2007 10:02 am
i use router OS 2.9.26 and i a novice and using router os for the first time as my college project
sergejs
Mon Jul 02, 2007 11:41 am
'web-proxy' package provides two options,
'ip web-proxy' that is based on squid,
'ip proxy' MikroTik proxy that does not support caching.
however the NEW 'web-proxy test' package provide one option,
'ip proxy' that is MikroTik proxy and supports caching.
tobi_cjr
Tue Jul 10, 2007 5:25 am
So what proxy prefered? IP PROXY or IP WEB-PROXY?
I have problem using (maybe bugs) this Mikrotik Proxy, because when someone accessed the web using Mikrotik Proxy for the first time, the page displayed will "Mikrotik Http Proxy Error 404: File Not Found". Then if I pressed 'refresh (F5)' again and again and the real page will be shown eventually. So what could it be?
If I upgrade the Mikrotik (my Mikrotik version is 2.9.6) will it resolve the problem?
Thx
normis
Fri Jul 13, 2007 3:20 pm
the new "webproxy test" in 2.9.44 is preferred. it has caching, is faster, and more reliable. made by mikrotik.
tgrand
Long time Member
Long time Member
Fri Jul 13, 2007 3:56 pm
Just do not enable it on a gateway
normis
Fri Jul 13, 2007 4:05 pm
and why is that?
epproach_lyle
Sat Jul 14, 2007 1:18 am
bump for that last comment.. don't get me confused :)
airstream
Sat Jul 14, 2007 8:34 am
What happens here? is this a security hole?
tgrand
Long time Member
Long time Member
Sun Jul 15, 2007 6:08 am
When enabled on the gateway, non of my clients can access pop3 or smtp.
This is simply enabling proxy.
No Nat rules or anything like that.
Happens with 2.9.43, 2.9.44, V3beta9, and 3beta10.
normis
Tue Jul 17, 2007 10:15 am
well that must be a problem with your config, as I can't confirm anything like it. please contact support with your supout.rif file
kiwi0428
Fri Jul 27, 2007 6:43 am
I tried set about web-proxy. But I still think some problem. And could I ask you a question?
Doesn’t web-proxy support dynamic web? How does I set that I can dynamic web storage on web-proxy cache?
Could you give a favor? Thank you so much…
My command of web-proxy’s setup….
Exam:
/ ip web-proxy
set enabled=yes src-address=0.0.0.0 port=8080 hostname="proxy" \
transparent-proxy=yes parent-proxy=0.0.0.0:0 \
cache-administrator="webmaster" max-object-size=500KiB \
cache-drive=secondary-master max-cache-size=1000KiB \
max-ram-cache-size=1000KiB
/ ip firewall nat
add chain=dstnat action=redirect to-ports=8080 src-address=192.168.1.0/24 \
dst-address=!192.168.1.1 dst-port=80 protocol=tcp comment="" disabled=no
sergejs
Fri Jul 27, 2007 9:01 am
Proxy is caching HTTP and FTP, transparent proxy is caching only HTTP.
kiwi0428, what do you have in 'ip web-proxy print' for status ?
http://www.mikrotik.com/testdocs/ros/2. ... 4212475922
Make sure that DNS servers are configured on 'ip dns' menu.
