patagonia
Vsat problem
Sun Jan 27, 2008 4:57 pm
Hi, I need to know if MikroTik can solve or to emulate an application used to navigate through a VSAT conection. The application is called IPA (Internet Page Accelerator) and here I send them a capture of the configuration screen. The objective is that the computers on the side of the LAN use the configuration granted by the DHCP, without having to configure manually on the browser the ip and port on proxy setting (localhost:9877), and not to have to have installed the IPA agent. If I share a second interface in the XP computer I can use it as server and listen petitions in the port 9877 as a net proxy, for that reason I suppose that miktotik has to have a solution without having to use the ($%"·$%&) XP....
Greetings.
Users browsing this forum: Bing [Bot], GoogleOther [Bot], mbovenka and 196 guests
