SA
Telnet
Fri Aug 29, 2008 2:18 pm
After upgrading to 3.13 from 3.10 my Net::Telnet perl scripts don't work anymore.
Seems like telnet server was changed, but I can't find anything about it in the changelog.
2.9 also works fine.
The ploblem is apparently with terminal type handling, 2.9 says "terminal type is network", 3.13 just hangs after the MikroTik banner.
sergejs
Re: Telnet
Fri Aug 29, 2008 4:18 pm
Scripting/console is changed between 2.9 and 3.0, but there should not be too much difference between 3.10 and 3.13 console functions.
vegard
Re: Telnet
Fri Aug 29, 2008 6:21 pm
We've also seen this with 3.x. Try hitting enter (send "\r\n") a few times. It also happens with mac telnet.
SA
Re: Telnet
Sun Aug 31, 2008 10:14 pm
There is nothing to "hit", the problem is with perl scripts (which worked fine with 2.9 and even with older 3.x versions).
Yes, there should not be too much difference, but seems like there is :(
Once again, the script does not receive command prompt, MT telnet server just hangs after login banner.
janisk
Re: Telnet
Mon Sep 01, 2008 1:15 pm
try to provide login parameters in you scripts.
SA
Re: Telnet
Tue Sep 02, 2008 10:07 am
Seems like nobody really reads my message :(
The script that works with 2.9 and 3.10 does NOT work with 3.13 due to some change in the console code.
It hangs after login (there is a "logged in via telnet" message in the /log).
normis
Re: Telnet
Tue Sep 02, 2008 1:04 pm
Please paste the entire script here, or send it to support, so we can check what is wrong with ROS 3.13
SA
Re: Telnet
Wed Sep 03, 2008 11:52 am
#!/usr/bin/perl
use strict;
use Net::Telnet;
unless (@ARGV > 2) { exit 2; }
my $nasip = shift(@ARGV);
my $community = shift(@ARGV);
my $login = shift(@ARGV);
my ($user,$pass,$t);
($user,$pass)=split(/:/,$community,2);
$t = new Net::Telnet (Timeout => 5,
                      Errmode => "return",
#                     Dump_Log => '/tmp/telnet.log',
                     Prompt => '/> $/');
if ($t->errmsg){
    exit 24;
$t->open($nasip);
if ($t->errmsg){
    exit 24;
$t->login($user, $pass);
if ($t->errmsg){
    exit 24; #returns here with timeout in 3.13
$t->cmd("/interface pppoe-server");
$t->cmd("remove [find user=\"$login\"]");
$t->cmd("/quit");
$t->close();
exit 0;
Here it is. The script is used to disconnect pppoe users
usage: disconnect.pl <mt ip> <mt username>:<mt password> <pppoe username>
SA
Re: Telnet
Tue Sep 23, 2008 11:01 am
Doesn't work in 3.14 either
mrz
Re: Telnet
Tue Sep 23, 2008 11:18 am
Have you tried it?
None of these scripts will work unless console colors and terminal detection is disabled
Chupaka
Re: Telnet
Tue Sep 23, 2008 12:04 pm
yesss, exactly =)
What's new in 3.0rc14:
*) console - added login parameters, passed as part of login name, after '+';
can be used to disable colors (+c) and terminal autodetection (+t), e.g.
"admin+ct";
Russian-speaking forum: http://forum.mikrotik.by. Welcome :)
For every complex problem, there is a solution that is simple, neat, and wrong.
¡ɹǝ|SOɹǝʇnoɹ ʞıʇoɹʞıW ɯ‚|
MikroTik. Your life. Your routing.
SA
Re: Telnet
Thu Sep 25, 2008 3:43 pm
Yes, it works with +ct, but the script must work with both 2.9 and 3.x. (and worked before 3.13).
Anyway, this is sort of a solution, thanks :D
Users browsing this forum: Baidu [Spider], gotsprings, irico, mati83 and 32 guests
