Post subject: RouterOS and SMP (multi-core and multi-cpu) crashes
Posted: Thu May 07, 2009 1:11 pm
Staff
Joined: Fri May 28, 2004 11:04 am Posts: 10765 Location: Riga, Latvia
We have made a new RouterOS build that supposedly fixes some issues that caused multicore systems to crash. If anyone is interested to test their previously crashing Xeon, i7, Core2Duo or any other machine with several processing parts, please contact support for a test package.
what modules of RouterOS does this fix affect? I have v3.22 on Core2Duo, works pretty stable (some previous versions of v3 tested with multi-cpu=yes were crashing)
_________________ For every complex problem, there is a solution that is simple, neat, and wrong.
I don't use layer7, but have more than 600 address lists entries, and some are changing from day to day - still no problems with multicore. and it's our Internet router (with PPP and Queueing). internal core routers uses even higher number of address-lists entries, they did not expirience multicore issues even on early v3 =) am I lucky?
Post subject: Re: RouterOS and SMP (multi-core and multi-cpu) crashes
Posted: Mon May 11, 2009 2:32 pm
sure?? you fix it. this is a very good news. can you sent that version because i had 4 mikrotiks level 6 all in multicore = no because they always crash. please sent that version i am very very very interest on it
Normis what is that version?. Because i sent a email to support and they said that all version are on the web.
My friend 111111 said that AMD never crashes bur Intel does :Р for multicore
_________________ I'm an ISP and I'm a certified Network & Telecom Professional (CCNA, R&M, M.Eng etc) I can relieve your pain! I configure routers. Payment - paypal and bank. Contact me - Skype: hypnologic http://www.mikrotik-bg.Net
It is a pre-release version of 3.24 (just few days older than one with PCC). Also there is winbox support for PCC included.
Regarding SMP - router that was crushing once or twice every day is up and running for 5 days now. (have 5 layer-7 filters and ~1000 address-list entries)
_________________ I know what i don't know, do you?
Did you test the machine with stresstest, for example StressPrime 2004 Orthos, so you would be sure that the RAM is fine and the cooling is OK?
Posted: Tue May 26, 2009 9:33 am
Staff
most people that reported crashes before, now have them all fixed with v3.24. I suspect there is something different in your setups, maybe configuration, maybe some specific motherboard family ...
Posted: Tue May 26, 2009 5:34 pm
I noticed that there is a problem with routers where we use hotspots there is no problem with router that only passtrough packets (no hotspot, no firewall rules, no queues) - one case
bakula: that router from picture - do You have hotspot/queue rules there?
Posted: Fri Jun 12, 2009 9:34 am
Staff
It's either Hotspot, VLAN or Simple Queues. Can you experiment with these features to narrow it down? Hotspot also uses Queuing and it can be run on VLAN
I can confirm that with an NEC Express server, Pentium 4 with Hyper Threading that any version of Routers os greater than 3.11 will lock up hard when HOTSPOT is enabled.
If I disable that package then the machine runs fine, Vlans and Queues work ok.
Enable the hotspot package and the machine locks hard about 5 seconds after the boot up tones. Then the only way to recover the machine is to remove the interface that the hotspot listens on and restart the machine. Removing the interface causes the HOTSPOT to be disabled, and then the machine will run. At this point I must downgrade to 3.11 to get a working machine, and put the Hotspot interface back in again.
Are your x86 machines tested before installing RouterOS on them? Did you stress test CPU + Memory? Is cooling sufficient? What about power - is it stable? You have to check for all these first. Because a lot of problems were solved by replacing RAM for example. When they tested it and knew it was not working.
No I have not specifically run those tests on the machine. Its an interesting point though.
The specifica machine I have in mind was installed in production as a mikrotik core router in 2006 with RouterOS version 2.9.something, and we have been progressively upgrading it since then, whilst always keeping a few versions behind. Its always been stable, but I guess things can change.
Its difficult to take this machine out of production to run those tests, but let me find a spare router and try it out.
Denis, before you go around making those comments take a little time to understand where the people are coming from.
Here in Africa (kenya in my case) it is not possible to buy your products. Yes I could import one and have it DHL over here but import duties are so high on something like that that it would be cheaper for me to buy Cisco.
Yes, thats right cheaper to buy cisco! They are a bigger company with a presence in Kenya and are able to use their slush funds effectively to ensure cheaper duties.
So, in the meantime guys like us manage with other solutions.
Something to think about: In kenya a 1mb up and down pure dedicated internet link via Vsat costs 3500 US Dollars per month.
Do me a favour and keep your marketing off the mikrotik forum.
Regards
Alex
P.s. apologies to all other people who read this thread. Feel free to flame me at info @ itworx.co.ke or block me from the forum. I am tired of Denis Burgess and his forum sales.
Denis thank you for the useful info. I could totally buy your stuff regardless of shipping costs. Its a principle thing. Its god to know what is stable and what not so tnx for the info.
Posted: Wed Jul 01, 2009 4:21 pm
Forum Veteran
Keep in mind that we do have a distributor in Africa, so you don't have to ship it form the US. Second, if you are using a 1 meg connection, why have a x86 at all! a 493AH would handle 99% of what you need and its super cheap and stable, vs messing with unsupported systems.
You buy Cisco cause you put it in and it works. You buy router boards and powerrouters for the same! If you buy a server and place RouterOS on it without fully testing it, you are in a crap shoot. It may work for a while, but is it cheaper ? Not really due ot the support time involved and maintaining it.
With that said, something to help the fourms, our 2282, Dual Quad Core Xeon Systems is working perfectly with 3.25 .. before that we had to go back to 3.6 I believe. But a bit more testing.
_________________ Dennis Burgess, CCNA, A+, N+, MCP, Mikrotik Certified Consultant / Trainer Need Mikrotik Support: http://www.linktechs.net -- Link Technologies, Inc. --- Author of "Learn RouterOS" -- routerosbook.com ---
As Juniper Elite partner we often come across companies where network purchasing decisions are made on the "no teal no deal" basis. For some reason a lot of people believe that Cisco is the only networking product that actually works!
Although I also do not agree with Dennis blatantly promoting his PowerRouter product via the user forums, I commend him for building and supporting a product that works. Maybe there is a better way for him to promote his product to Mikrotik users that will not offend people on the forum?
Posted: Thu Jul 02, 2009 12:04 am
Forum Veteran
Ya know, you can't make everyone happy. Some people are more than happy to find something that is supported and tested, and others are just offended for someone recommending something other than what they have. But if you will notice, I also saw that they only had a meg of bandwidth, and I recommended that they use a 400AH series! Routerboard will more than handle that amount of load! I recommend what is necessary!
Posted: Sat Jul 04, 2009 6:36 pm
Forum Veteran
You are saying it has nothing to do with hardware/memory, and yes, i would agree that it "should" work. However, the fact is that it don't with YOUR hardware. So guess what, if you go buy other platforms, i;.e cisco, juniper, you can't put their software on your "DELL". So now you have to buy their hardware/software as a substantial price increase.
The whole point with RouterOS is that you can put it on your hardware, but if you want to put it on hardware that is not tested, etc, then you are making the decision to do so.. I suggested to use hardware that we know works with mulit-core and you won't have that issue.
Posted: Mon Jul 06, 2009 10:00 am
Staff
There is more than "it's also Linux, so it should work!". If you must complain, do it to support, not here. Topic will be locked because some people can't control their aggression.
Users browsing this forum: jmoore, mhoppes and 18 guests
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot post attachments in this forum
