hamed89156
ROUTER HAS NO SOFTWARE KEY
Fri Jul 03, 2009 10:15 pm
I have downgraded my routeros on 450g from version 4 beta3 to version 3.23
as i enter the RB via telnet i face the bellow message :
You have 20h59m to configure the router to be remotely accessible,
and to enter the key by pasting it in a Telnet window or in Winbox.
See http://www.mikrotik.com/key for more details.
Current installation "software ID": BlahBlahBlah,,,,
Please press "Enter" to continue!
and as i wanna import my license key in system>license>import
i face the bellow error :
"Could not change the key - invalid key "
again i tried to copy the content of license key file and past in mikrotik but after restart i again see that no changes are make.
please help me
normis
Re: ROUTER HAS NO SOFTWARE KEY
Mon Jul 06, 2009 11:22 am
contact mikrotik support with key related issues
Chupaka
Wed Jul 08, 2009 12:41 am
xxxx-xxxx softID on 3.23? O_o
wow...
Wraiths
Thu Dec 31, 2009 2:20 am
I have this exact same problem as well and I have contacted support and they have provided me with a new key but I cannot get the new one to stick. I have tried through winbox, hyperterminal, and the new terminal in winbox and still without success. If anyone has any ideas what I'm doing, I would really appreciate knowing.
Thank you in advance,
James
ilius168
Thu Dec 31, 2009 9:15 am
had exactly the same problem with 1 RB 433AH and 1 RB 1000u, contacted support, rb433ah fixed with new software key given, but not with the RB 1000u,
problem: license expiring within 23+ hours, had to hard reboot (soft reboot won't reboot at all) the unit then it went expiring again and again. upgraded from 4.3 to 4.4 with no effect.
re-install using netinstall without any success neither.
will send the unit back for RMA, bugger!!! :-x
Users browsing this forum: andrewrmack, yonutm and 59 guests
