keefe007
Port Mirroring
Wed Jul 15, 2009 2:30 am
Is it possible to do port mirroring on a Mikrotik for monitoring purposes? I see there's a interface ethernet mirror command but I can't figure out how to use it.
Keefe
andrewluck
Forum Veteran
Forum Veteran
Re: Port Mirroring
Mon Jul 27, 2009 12:04 am
Documentation is a little thin on this subject. I found this is a config file:
/interface ethernet mirror
set mirror-port=none source-port=none
Hope this offers some clues.
Kind regards
Andrew
keefe007
Re: Port Mirroring
Mon Jul 27, 2009 12:20 am
That doesn't seem to work:
/interface ethernet mirror> set mirror-port=ether5 source-port=LAN
bad argument name mirror-port (line 1 column 5)
changeip
Re: Port Mirroring
Mon Jul 27, 2009 1:48 am
does it have to be a port thats in a switch config ?
Colo and Wholesale Bandwidth Available! Sales at SanDiegoBroadband dot com
roc-noc.com
Forum Veteran
Forum Veteran
Re: Port Mirroring
Mon Jul 27, 2009 1:55 am
This is the command syntax. I tried it on an RB493AH with ROS 3.27 but it doesn't appear to be working yet. I tried bridging the ports, slaving the ports, leaving them not bridged and not slaved.
"interface ethernet mirror set source-port=ether8 mirror-port=ether9"
source-port does not support being mirrored
It looks like a future command and one I look forward to.
Tom
http://www.roc-noc.com
Tom, CCNA, ISP, USA Mikrotik Distributor
888-762-5662
maco
Re: Port Mirroring
Mon Jul 27, 2009 2:44 am
Im looking for the same functionality. Can you please update us on the topic in case you have any new information?! Thank you.
normis
Re: Port Mirroring
Mon Jul 27, 2009 9:20 am
This is supported on some RouterBOARDs that have appropriate switch chips that support port mirroring. For example RB450G and RB750
maco
Re: Port Mirroring
Mon Jul 27, 2009 1:42 pm
Very helpful! Cheers!
keefe007
Re: Port Mirroring
Mon Jul 27, 2009 11:56 pm
Would it be possible for you to extend this feature to any kind of network interfaces using software instead of the hardware chips?
Keefe
normis
Re: Port Mirroring
Tue Jul 28, 2009 8:52 am
that would take too much resources! imagine what this does - it mirrors all traffic!
keefe007
Re: Port Mirroring
Tue Jul 28, 2009 10:12 pm
You don't think a dual/quad core x86 box or a dual processor multi-core x86 box wouldn't be able to handle that? I have low end 8 port HP managed switches that can do port mirroring.
Keefe
normis
Re: Port Mirroring
Wed Jul 29, 2009 8:54 am
those switches have switch chips, they don't have operating systems doing this in software!
keefe007
Re: Port Mirroring
Wed Jul 29, 2009 9:27 am
What specific chipset is required to make this happen? Are there and pci cards available with this chipset?
normis
Re: Port Mirroring
Wed Jul 29, 2009 9:28 am
RouterBOARD 750 and 450 have this switch chip.
keefe007
Re: Port Mirroring
Wed Jul 29, 2009 10:24 am
What is the exact name of the chipset/chip needed? Or, what is the exact technology these chips must have to support this?
I would like to find out if there are and pci or pcie based network cards that have this chipset or support this echnology.
normis
Re: Port Mirroring
Wed Jul 29, 2009 10:29 am
RouterOS doesn't support any other chips
csickles
Re: Port Mirroring
Tue Sep 08, 2009 8:27 am
Just because I havent had time to try it..
Is it both ingress and egress ??
Things that make you go "Hmmmmmmmm"...
Craig
csickles
Re: Port Mirroring
Wed Oct 07, 2009 1:01 am
FYI...
Both Ingress and Egress as well as injection ARE supported !!! Yahoo !!!
I am uning the 450G as a net tap for a FaceTime box..
WORKS GREAT !!!!
Setup was about 15 Min !!
Craig
brianlj
Re: Port Mirroring
Wed Jul 27, 2011 5:46 pm
I am using an RB450 and the mirror command does not seem to be available under the ethernet menu?
Am I missing a required package?
Software version is 4.11.
kirshteins
Re: Port Mirroring
Thu Jul 28, 2011 8:36 am
Check under "/interface ethernet switch print". If the type is "ICPlus175C", then mirroring is not supported.
brianlj
Re: Port Mirroring
Thu Jul 28, 2011 5:29 pm
It is type IC-Plus-175D.
I was able to use command:
/interface ethernet switch set numbers=0 mirror-source=ether2 mirror-target=ether5
Does this accomplish the port mirroring? I was not able to find any documentation anywhere.
kirshteins
Re: Port Mirroring
Fri Jul 29, 2011 8:42 am
Yes, port mirroring is supported on this chip. More information: http://wiki.mikrotik.com/wiki/Switch_Chip_Features
brianlj
Re: Port Mirroring
Fri Jul 29, 2011 5:02 pm
I still didn't find a mirror command under the ethernet menu (as shown in above posts)?
Is there any good documentation out there for supported commands?
Did my sample command look correct?
Thanks!
kirshteins
Re: Port Mirroring
Mon Aug 01, 2011 7:55 am
Yes,
is correct. Please describe the problem you are experiencing.
brianlj
Re: Port Mirroring
Mon Aug 01, 2011 4:51 pm
Thank you.
I was just trying to confirm command syntax since I could not find reference and this topic thread indicated the command was "interface ethernet mirror set source-port=ether8 mirror-port=ether9".
I believe all is working OK. Is there a way to confirm the mirroring activity?
kirangaj
Re: Port Mirroring
Thu Oct 03, 2013 6:06 pm
Hi All,
I was able to set one of the ports as mirror ports, I am trying to set other two ports too as mirror ports for the same source port, Is that possible?
Could someone help me with this?
Regards,
Kiran G
kirangaj
Re: Port Mirroring
Fri Oct 11, 2013 3:40 am
Could some one help me with configuring the mirror ports? I want to have three destination ports for the same source port? Is that possible?
Users browsing this forum: SteloNLD and 15 guests
