directlogic
NTP on Mikrotik
Wed Sep 30, 2009 4:52 pm
Dear All,
I have Mikrotik RB333 and RB411 routers and i connected these routers with private ip's(192.168.0.0/24) on wlan and live ip's on ethernet.
I m unable to setup NTP client on there router's these router not sync with NTP server's
how can i sync there router with private ip to sync with NTP server.
Thanx.
Chupaka
Re: NTP on Mikrotik
Wed Sep 30, 2009 5:04 pm
what NTP server do you use? can you ping it?
Russian-speaking forum: http://forum.mikrotik.by. Welcome :)
For every complex problem, there is a solution that is simple, neat, and wrong.
¡ɹǝ|SOɹǝʇnoɹ ʞıʇoɹʞıW ɯ‚|
MikroTik. Your life. Your routing.
mrz
Re: NTP on Mikrotik
Wed Sep 30, 2009 5:07 pm
also make sure that mode=unicast
by default it is set to broadcast
directlogic
Re: NTP on Mikrotik
Wed Sep 30, 2009 5:16 pm
Dear Chupaka
I m using 120.88.47.10 server.
which is pinging from Rb which have live ip but unable to ping from Rb which have private ip.
That ntp server working fine on RB1000.
My Question is how to sync ntp from RB which have following ips:-
Wlan = 192.168.1.1/30 (private)
Ethernet =204.56.x.x/30 (public)
ntp mode =unicast
Chupaka
Re: NTP on Mikrotik
Wed Sep 30, 2009 5:20 pm
you either need to give RBs access to internet via RB1000, or just setup NTP server on RB1000 (by installing 'ntp' package) and then sync RBs with RB1000
directlogic
Re: NTP on Mikrotik
Thu Oct 01, 2009 1:12 pm
Each RB has the internet access on ehternet port but not on wlan
i m not able to ping ntp server directly and only ping by giving source address(ehternet that is live) in advanced tab.
fewi
Re: NTP on Mikrotik
Thu Oct 01, 2009 6:01 pm
Can you post the output of "/ip route print"?
Specific answers require specific questions. When in doubt, post the output of "/ip address print detail", "/ip route print detail", "/interface print detail", "/ip firewall export", and an accurate network diagram.
directlogic
Re: NTP on Mikrotik
Thu Oct 01, 2009 7:15 pm
Following is my route detail:-
# DST-ADDRESS PREF-SRC GATEWAY-STATE GATEWAY DISTANCE INTERFACE
0 A S 0.0.0.0/0 reachable 10.10.1.1 1 wlan1
1 ADC 10.10.1.0/29 10.10.1.2 0 wlan1
2 ADC 120.120.X.X/29 120.120.X.X 0 ether1
fewi
Re: NTP on Mikrotik
Thu Oct 01, 2009 7:25 pm
Set a default route that allows the devices to reach the NTP server, or implement a specific route for the NTP server IP.
directlogic
Re: NTP on Mikrotik
Fri Oct 02, 2009 6:29 pm
Thanx fewi
Its works . But when Rb reboot and come back it display jan/01/1970 and after that it display the correct time. I think when rebooted it lost the NTP connection and when it connect with AP it got sync with NTP server.
Any ways thanx for suggestion.
fewi
Re: NTP on Mikrotik
Fri Oct 02, 2009 7:31 pm
Yes, that is expected behavior.
marioclep
Re: NTP on Mikrotik
Wed Oct 07, 2009 4:50 pm
directlogic wrote:
Each RB has the internet access on ehternet port ...
If you have internet access, then why don't you try to sync with a public ntp server (such as: 0.pool.ntp.org) just to find out if the problem persist?
Ing. Mario D. Clep
CTO - MKE Solutions
MikroTik Certified Trainer
directlogic
Re: NTP on Mikrotik
Wed Oct 07, 2009 8:36 pm
Mario
it is sycn with ntp server .but the problem is that when it rebooted it show the 1970 date and time, so i can't get the date and time of reboot or power failure .
changeip
Re: NTP on Mikrotik
Wed Oct 07, 2009 9:01 pm
RouterBoards still do not have batteries in them so they dont keep time on a reboot.
Sam
Colo and Wholesale Bandwidth Available! Sales at SanDiegoBroadband dot com
samsung172
Re: NTP on Mikrotik
Sun Oct 11, 2009 11:14 pm
btw... why broadcast as default? whos has an broadcasting NTP server as default at the broadcast domain?
roc-noc.com
Forum Veteran
Forum Veteran
Re: NTP on Mikrotik
Sun Oct 11, 2009 11:26 pm
directlogic wrote:
Mario
Use a syslog server. That will at least show you the time and date when the RouterBoard starts back up. If power failures are a big problem then get a smart UPS with ethernet interface and log alarms from that.
Tom
http://www.roc-noc.com
Tom, CCNA, ISP, USA Mikrotik Distributor
888-762-5662
marioclep
Re: NTP on Mikrotik
Tue Oct 13, 2009 2:53 am
directlogic wrote:
Mario
When I said that, my idea was to find out if the RB could get the time again after reboot from a public ntp server. Also check if you have the "invalid packets" rule in your input-chain.
Ing. Mario D. Clep
CTO - MKE Solutions
Users browsing this forum: keithy and 10 guests
