squishio
setting up 3g modem
Fri Oct 30, 2009 5:06 pm
Hi All
Fairly new to networking and routeros so bear with me, does anyone have a general guide to setting up 3G on a ROS?
I have got a couple of 3g usb dongles and need to get them running as my sole connection. I have setup a ppp client on the 3g port but that is about it, I haven't setup any dhcp client etc as the 3g is not listed as an interface when selecting one to enable dhcp on.
is there a wiki guide for 3g somewhere?
Any help much appreciated!
Thanks,
Rich
normis
Re: setting up 3g modem
Fri Oct 30, 2009 5:21 pm
we have several guides actually, this one will be for your situation:
http://wiki.mikrotik.com/wiki/Option_Gl ... _USB_Modem
squishio
Fri Oct 30, 2009 6:09 pm
aha! not sure how I didnt find that :roll:
have got stuck though, when I run....
[admin@rb411u] > /system serial-terminal usb2 channel=2
I do not get any response, I only get...
[Ctrl-A is the prefix key]
but I should be getting somthing like...
ATI
Manufacturer: Option N.V.
Model: GTM378
Revision: 2.3.3Hd (Date: Jul 17 2007, Time: 15:49:23)
OK
any idea's?
I might try another type of usb stick :-/
HermanK
Sat Oct 29, 2011 4:50 pm
I need some help, and I will be very great full if you can assist.
I have a RB411u with a ZTE MF190 modem connected via usb, the modem does connect to the internet (See pic) as I am able to ping Yahoo.com.
But I can’t connect to the web via my pc ……
jandafields
Tue Nov 01, 2011 6:29 am
You need to start a new topic, and not hijack this one... but it looks like you probably didn't setup NAT Masquerade. Don't forget to setup nat-masquerade and dns if you want pc's to connect to Internet through your router with a single public IP address!!!
rahan
Wed Jul 04, 2012 8:21 pm
will you post ppp-client confuguration
tzupan
Fri Aug 08, 2014 4:01 pm
jandafields actually I do exactly all of the things in manial (wiki), but I can't get my ZTE MF190 to use 3G.
In compatibility table is written that I need to use data channel 3 (I can't because winbox said that it's not allowed) and info channel of 1 - this one is working.
Any idea please to fix my isue that internet is woring only on GSM compact... :(
Thanks!
Users browsing this forum: Google [Bot], malevans and 22 guests
