AdminSpeedNet
Hotspot Account Generator
Fri Nov 20, 2009 9:08 am
I create hotspot account manually in WinBox. But this is a very tired job to create one by one. Is there a way to generate random hotspot accounts?
nest
Forum Veteran
Forum Veteran
Re: Hotspot Account Generator
Sat Nov 21, 2009 4:04 am
yes, use Usermanager for hotspot AAA and then, under "users / add batch" menu there is a simple method to generate many vouchers with random names.
Create Batch.gif (21.09 KiB) Viewed 7670 times
AdminSpeedNet
Sat Nov 21, 2009 6:39 am
I've generated a few vouchers but it isn't exist when I try to login. Also no records in Hotspot --> Users when I check in WinBox. Does it generate and save to Mikrotik? or just generate?
fewi
Sat Nov 21, 2009 7:00 am
User Manager is essentially a RADIUS server. It's a rather large topic, and too much to cover in a post.
The documentation is rather extensive and can be found here: http://wiki.mikrotik.com/wiki/User_Manager
nest
Forum Veteran
Forum Veteran
Sat Nov 21, 2009 2:11 pm
Usermanager is a completely separate database, the users created in Usermanager are in a Radius database, not in "Winbox Users". Agree with fewi, you still have more to learn! :-)
AdminSpeedNet
Sun Nov 22, 2009 9:59 am
Is Radius server another MikroTik RouterOS?
nest
Forum Veteran
Forum Veteran
Sun Nov 22, 2009 2:30 pm
No. It's part of the Usermanager package. See this page http://wiki.mikrotik.com/wiki/User_Mana ... er_Manager
It is best practise that you host Usermanager on a seperate ROS, but there is nothing to stop you installing the package on the same router as your hotspot if you only have a limited number of accounts.
Ron Touw - Mikrotik Certified Trainer
LinITX.com - MultiThread Consultants
Get your MikroTik RBs and Training: http://linitx.com/category/166
Largest Official UK MikroTik Distributor
IRC channel: #routerboard on irc.z.je (IPv4), 6.irc.z.je (IPv6)
AdminSpeedNet
Mon Nov 23, 2009 7:08 am
So Radius server can be install in MikroTik RouterOS?
dssmiktik
Forum Veteran
Forum Veteran
Mon Nov 23, 2009 7:46 am
UserManager is a RADIUS server, suited for use as authentication mechanism for Mikrotik devices. UserManager can be installed on Mikrotik RouterOS.
You could use the full FreeRADIUS package on a separate machine (not Mikrotik), but you may not need all of its features, or want to spend to time to set it up. This is one of the areas where Mikrotik UserManager shines.
For more information on Mikrotik UserManager, visit:
Doug
AdminSpeedNet
Mon Nov 23, 2009 7:56 am
I'm not sure if Radius Package is NPK file of RouterOS or another OS? Can you show me where to download it?
dssmiktik
Forum Veteran
Forum Veteran
Mon Nov 23, 2009 8:04 am
Yes, User Manager is an NPK file for RouterOS.
The latest User Manager package can be downloaded from:
http://www.mikrotik.com/download.html
1. Choose your RouterOS model, then choose the version.
2. Select the "All Packages" link.
3. Unzip it, and copy user-manager-<version>-<system>.npk to your RouterOS.
4. Reboot your router and it will automatically install the User Manager.
Hope this helps.
Doug
AdminSpeedNet
Mon Nov 23, 2009 8:18 am
It is USER_MAN.NPK? Already installed. Now my RouterOS is a Radius Server?
fewi
Mon Nov 23, 2009 8:32 am
Start by reading the wiki page that has been linked to three times in this thread.
AdminSpeedNet
Mon Nov 23, 2009 8:44 am
That is a complete understanding manual. It is really difficult to read them all. Can you just teach me the easy part first before I learn the detail of all function about Radius? Can you show me how to install and basic configuration before the Advanced Part?
dssmiktik
Forum Veteran
Forum Veteran
Mon Nov 23, 2009 12:01 pm
AdminSpeedNet,
Please, as fewi mentioned:
Report this post
this is quite an extensive topic. Mikrotik User Manager has many options and functionality. If you have a question about specific functionality within User Manager, feel free to ask it, but this forum is NOT for complete training on RouterOS.
For training: http://training.mikrotik.com/
You can find a consultant for Mikrotik here: http://www.mikrotik.com/consultants.html
If you still have troubles, consider contacting Mikrotik Support: [url]support@mikrotik.com[/url]
Everyone has to equally read the same manual / wiki / forums to find answers.
Doug
andreacoppini
Wed Jan 26, 2011 1:00 pm
Sorry for hijacking this thread, but as AdminSpeedNet stated, User Manager can be too cumbersome in some scenarios.
For this reason I've written a simple hotspot account generator, please see this thread --> viewtopic.php?t=48111
Enjoy
- No strings attached -
<< Please give good Karma if this post helped you. Press the + button above the Location entry
Users browsing this forum: dariop84 and 27 guests
