Hi to all,
I'm new of this forum.
I use Mikrotik RouterOS since 2005 and now I want to enable Hotspot on my RouterOS 2.9.45
Some months ago I configured Web-Proxy in Transparent-proxy Mode with a Parent Proxy (Squid 2.7.STABLE4).
I configure Web-proxy Logging on Mikrotik because Squid see all incoming request from the Mikrotik IP and not from the client IP.
Now I want to use hotspot and I follow the Mikrotik guide available at http://www.mikrotik.com/testdocs/ros/2.9/ip/hotspot.php
I configure the hotspot in order to use the parent proxy defined in Web-Porxy settings and all works fine.
The hotspot forward all request to Parent-proxy but Hotspot doesn't log it in web-proxy logging.
Could someone help me?
I need these logs!
Many thanks!
