Tue Feb 02, 2010 5:42 pm
OK, I've figured I don't need microSD card to be able to log to file. However, I still have a following problem...
I'm using following script:
:local interface "wlan1";
/interface wireless monitor $interface once do={
:local snr $"signal-to-noise";
:log info "SNR: $snr";
Info is configured to use 'disk' as action, and script saves SNR value in a file each time the script is run.
However, if I create topic 'wireless' and set 'disk' as action, and change the last line in the above script to:
:log wireless "SNR: $snr"; it doesn't save SNR value in a file...
What did I do wrong?
Zreno
