pyrosster
Mikrotik and subnets
Tue Feb 02, 2010 7:05 pm
I configured mikrotik to show a hotspot informative page showing coverage using a range 192.168.182.x/24 for this. Also I have a few WRT54G configured in subnet 192.168.183.x/24.
Mikrotik have 3 interfaces:
1º Internet 192.168.2.x
2º Lan 192.168.0.x
3º Wireless 192.168.182.x (APs 192.168.183.x)
I want to have SNMP access from 192.168.2.x network to 192.168.183.x and allow these APs to reach SNMP server on 192.168.2.x.
Could anyone help me please?
Regards.
SurferTim
Re: Mikrotik and subnets
Tue Feb 02, 2010 7:19 pm
You will probably need to dstnat/srcnat an ip into your localnet
add chain=dstnat action=dst-nat dst-address=192.168.2.x to-addresses=192.168.183.y place-before=0
add chain=srcnat action=src-nat src-address=192.168.183.y to-addresses=192.168.2.x place-before=0
I would recommend this only if you have more than one ip assigned to your WAN interface. Otherwise, you will not be able to access the WAN router.
pyrosster
Tue Feb 02, 2010 9:12 pm
I have tried the above firewall rules and it dont work. I have tried:
add chain=dstnat action=dst-nat dst-address=192.168.2.25 to-addresses=192.168.183.1 place-before=0
add chain=srcnat action=src-nat src-address=192.168.183.1 to-addresses=192.168.2.25 place-before=0
What I'm doing wrong? I only need access to port 161 SNMP of the AP from 192.168.2.0 network.
Best regards.
SurferTim
Tue Feb 02, 2010 9:19 pm
If you want just that one port redirected:
add chain=dstnat action=dst-nat dst-address=192.168.2.25 dst-port=161 to-addresses=192.168.183.1 to-ports=161 place-before=0
add chain=srcnat action=src-nat src-address=192.168.183.1 src-port=161 to-addresses=192.168.2.25 to-ports=161 place-before=0
pyrosster
Tue Feb 02, 2010 9:36 pm
Hi again,
Dont work as expected. I enable these firewall rules, and I ping from mikrotik to 192.168.2.25 and I get no response. I think something is wrong.
What can I check?
Regards.
SurferTim
Tue Feb 02, 2010 9:43 pm
You are not going to get a response from your internal server if you are using ICMP (ping) to that address. Different protocol. That goes to the router. It is not forwarded to the internal server. Only port 161 is forwarded.
Users browsing this forum: homerouter and 113 guests
