Code: Select all
0 R name="Master" mtu=1500 mac-address=00:0C:42:53:FD:E7 arp=disabled
slaves=BOND1,BOND2,BOND3,BOND4 mode=802.3ad primary=none
link-monitoring=mii-type2 arp-interval=100ms arp-ip-targets=0.0.0.0
mii-interval=10ms down-delay=3ms up-delay=3ms lacp-rate=1sec
transmit-hash-policy=layer-2
Code: Select all
(GSM7248) #show port-channel all
Port- Link
Log. Channel Adm. Trap STP Mbr Port Port
Intf Name Link Mode Mode Mode Type Ports Speed Active
lag 1 CoreA Up En. En. En. Dynamic 0/2 Auto True
0/4 Auto True
0/6 Auto True
0/8 Auto True
Also, if i reboot the router for any reason, the BOND port will not work. I have to again, disable the bond port, and reenable it.
I've tried several small changes, i.e. changing the mii-type from 1-2 and back... I'm mostly curious if anybody have seen this problem before. and if so what their fix was.
