litu
Simple Queue problem for Bridge/PPPoE Users
Mon Mar 22, 2010 11:17 pm
Dear All,
I have found a problem in Mikrotik Router OS (example version is 4.6 for intel x86) which
is:
1. If I disable "Use IP Firewall" in bridge settings, all simple queues for bridge are not working and not limiting traffic ! But PPPoE USers are ok.
2. If I Enable "Use IP Firewall" in Bridge settings, all PPPoE users traffic not limiting but Bridge users are working just fine.
My question is: How can I traffic for both PPPoE & Bridge users in mikrotik ??
I saw in RB450, its just working fine ! Here (in RB450) in Bridge settings all are checked ! I mean enabled !
Please tell me what to do ??
Any suggestion ??
Regards.
Shah Ahmed Raquib Litu
Chief Technical
SOL-BD
Broadband Internet
33 Housing Estate, Amberkhana
Sylhet-3100.Bangladesh.
E-Mail: litu@sol-bd.com
Tel:+880 821 724500,724499 (10Am-5PM)
Cell: +880 1552359459
Chupaka
Re: Simple Queue problem for Bridge/PPPoE Users
Tue Mar 23, 2010 8:00 pm
and what about 'Use IP Firewall for PPPoE'? =)
Russian-speaking forum: http://forum.mikrotik.by. Welcome :)
For every complex problem, there is a solution that is simple, neat, and wrong.
¡ɹǝ|SOɹǝʇnoɹ ʞıʇoɹʞıW ɯ‚|
MikroTik. Your life. Your routing.
litu
Tue Mar 23, 2010 10:38 pm
Let me check with this and I will get back to you !
Chief Technical
SOL-BD
Broadband Internet
Ibersystems
Wed Nov 24, 2010 12:57 am
Ihave a customer with isues with simple queues+ros4.x+x86. Queues ar not limiting speed of users.
Martín
martinruiz at ibersystems.es
Experto en redes WiFi y enlaces WiFi.
Facebook: @Ibersystems
Twitter: @Ibersystems
Certified in Traffic Shaping, Wireless, Internetworking, Routing and User Management.
MTCTCE - MTCWE - MTCINE - MTCUME - MTCRE
litu
Wed Nov 24, 2010 9:06 pm
this problem happen when bridge, pppoe services are running on the same box, i.e x86 machine. I had 3 interface. 1-wan, 1-lan-pppoe-server, 1-bridge.
If I fix the traffic limiting issue with pppoe users, bridge interface can not control/limit traffic and
if bridge interface is fixed to control traffic, in that case pppoe users queues are not limiting.
I saw in the forum that its depends on bridge>seettings where I can select
use IP firewall
use IP firewall for pppoe users
use IP firewall for VLAN
this control the activities related to traffic shaping. But I failed to fix it.
Do you have such case ??
Regards
Chief Technical
SOL-BD
Broadband Internet
Users browsing this forum: josecortina, moditiger, santoperdido and 14 guests
