• MikroTik.com
  • RouterBOARD
  • User Meeting
  • Training
  • User Manual
  • Support
  • Downloads
  • Videos
Register |   * Login | HOME
View unanswered posts | View active topics
PPPoE/RADIUS - reset accounting session  Page 1 of 1
 [ 2 posts ]  Post new topic Reply to topic
  Print view Previous topic | Next topic
Author Message
davidsm
 Post subject: PPPoE/RADIUS - reset accounting session
PostPosted: Thu Apr 29, 2010 1:46 am
Offline
I've looked at some posts from a couple of years ago but couldn't find anything recent.
I'm using several MikroTik routers as PPPoE servers for ethernet connected retail clients at several sites. The routers are configured to use a central RADIUS server for authentication and accounting. To allow for offpeak downloads, I would like to reset the accounting session at 02:00 and 08:00 each day.
Is there any way to do this without terminating the actual PPP connection to the client? I really don't want to disconnect them twice a day. I don't have control over the client PPPoE routers so any solution needs to be initiated from the server side. I've tested cancelling the PPPoE active session and having the client router automatically reconnect but this terminates a running process on the client PC (I tested using wget).
I've also read that if you use PPPoE rather than hotspot then the router only accepts a subset of the Change of Authorization (/radius incoming) messages supported by MikroTik. Is this still true?
Top
 Profile
sergejs
 Post subject: Re: PPPoE/RADIUS - reset accounting session
PostPosted: Thu Apr 29, 2010 8:24 am
Offline
As far as I know PPP supports only disconnect messages, which means that client will be disconnected, in order to get new accounting/limitation options.
Top
 Profile
Display posts from previous:  Sort by
Post new topic Reply to topic  Page 1 of 1
 [ 2 posts ]
Board index » RouterOS » General
Users browsing this forum: ajmacias, paoloaga and 22 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB® Forum Software © phpBB Group
Karma functions powered by Karma MOD © 2007, 2009 m157y
