Im trying a setup and would like some input before i try it in the field.
1 rb411ah/r52h
mode=ap bridge ssid=cpe-only WDS=dynamic/bridge1 ip=192.168.1.5/24
added virtualAP ssid=main-site1 WDS=dynamic/bridge1
added virtualAP ssid=main-site2 WDS=dynamic/bridge1
Channel will probably be changed weekly due to interference
clients will connect to the main interface
rb411 ssid=cpe-only WDS=dynamic/bridge1 mode=station wds <<will this follow if i change channels?
ether1 ip=192.168.1.100
customers PC or router ip 192.168.1.200 "we assign IP addresses for public static"
would this mode allow transparency to their PC or Router?
Like station pseudobridge?
And also follow any channel changes
BH from site 1 to connect to virtualAP1
rb411 ssid=main-site1 WDS=dynamic/bridge1 mode=wds slave
Now we have more infrastructure behind this all in the same network
Will this work just like bridge mode.. but follow if we change channels on the main AU?
BH from site2 to connect to virtualAP2
Everything the same as site1 except for ssid
last but not least..
Would this all still work if DFS mode is on radar detect on the AP?
Thanks.. any input would be helpfull
