morgy
reset 411/411R
Thu May 06, 2010 8:05 pm
Hi
I tried to setup my routerboard 411/411R in bridge mode,
but accidentally I had disable Ethernet interface by Winbox, and now I cannot enter in my router (winbox doesn't find nothingh and I cannot ping it by ethernet interface!!)
How can I reset my router?
Feklar
Re: reset 411/411R
Thu May 06, 2010 11:22 pm
Time to pull out the good old console cable.
morgy
Re: reset 411/411R
Fri May 07, 2010 10:31 am
Can you please tell me if is it cross cable? (female-female)
and the connection from Hyper Terminal is ok?
thanks a lot
temuri426
Re: reset 411/411R
Fri May 07, 2010 2:59 pm
hi ...you can connect to router by hyperterminal....or securecrt... i've experienced the same problem
it's not cross cable.... see this https://specialcomp.com/beagleboard/null_modem.jpg
if your pc doesn't support db9 ports you can use db9-to-usb convertor...
morgy
Re: reset 411/411R
Fri May 07, 2010 3:16 pm
ok!
can you please tell me the correct command by Hyperterminal for reactivate ethernet interface?
Thank you very much
temuri426
Re: reset 411/411R
Fri May 07, 2010 3:42 pm
just click on interfase , then right click on your mouse and there is a enable command, thats all..
morgy
Re: reset 411/411R
Fri May 07, 2010 3:57 pm
but from Hyper Terminal can I use a mouse? are you sure?
from Hyper Terminal I think need to use command line, is it correct? and if need to use command line wich is the correct command?
Thank you
temuri426
Re: reset 411/411R
Fri May 07, 2010 4:15 pm
i forgot about it . :? .. do this:
interface enable <interface name>
if dont remember what is the name of the interface just type :
interface print
morgy
Re: reset 411/411R
Fri May 07, 2010 5:16 pm
thanks a lot!
in Hyper Terminal the configuration is:
serial
port comxx
baud rate 9600
data bits 8
parity none
stop bits 1
no dts/dsr
no rts/cts
no xon/xoff
is it correct?
thank you
Feklar
Re: reset 411/411R
Fri May 07, 2010 5:43 pm
Baud rate should be 115200
morgy
Re: reset 411/411R
Fri May 07, 2010 5:44 pm
interface print
115.000 bauds and is ok :)
the correct command I think is interface enable ether
but after I need save the new configuration or I can reboot and the new configuration is automatic saved?
thanks a lot
Feklar
Re: reset 411/411R
Fri May 07, 2010 5:48 pm
Yes, any changes you make to the router are instantly saved and active unless you are entering a config in safe mode. If safe mode is enabled, if you are logged out improperly from the router, it will revert the config back to what it was before you entered safe mode.
morgy
Re: reset 411/411R
Fri May 07, 2010 6:07 pm
thanks a lot for your kindness
now RB works again :)
Users browsing this forum: VirtualEvan and 113 guests
