• MikroTik.com
  • RouterBOARD
  • User Meeting
  • Training
  • User Manual
  • Support
  • Downloads
  • Videos
Register |   * Login | HOME
View unanswered posts | View active topics
Read Backup Configuration  Page 1 of 1
 [ 5 posts ]  Post new topic Reply to topic
  Print view Previous topic | Next topic
Author Message
cmurrayis
 Post subject: Read Backup Configuration
PostPosted: Wed Jul 14, 2010 6:53 am
Offline
I have a remote AP that played up this morning and lost one of it's key IP addresses. I have a backup conf from the other week but cannto afford any downtime to the customers running on the AP, Is there a way I can read the script from the Backup file to Find the Ip address and which Interface it was applied to?
I did the /export backupfilename and have the script file, but not sure how to read the file as my only access to the router is MAC telnet and winbox won't connect to it :S
Hope somsone has a quick answer for me.
Cheers
Cameron
Top
 Profile
mrz
 Post subject: Re: Read Backup Configuration
PostPosted: Wed Jul 14, 2010 9:48 am
Offline
Configuration exported with "/export" command is simple text file containing ros commands.
Just open it with any text editor.
Top
 Profile
leonset
PostPosted: Wed Jul 14, 2010 12:28 pm
Offline
If I understand correctly, the problem is that the export file is on the AP and can't get the file to a computer to read it...
I don't know if you can "cat [filename]" from within RouterOS telnet... Probably the best solution would be to just import the old export if haven't done many changes to it's configuration.
Regards,
Victor.
Top
 Profile
normis
PostPosted: Wed Jul 14, 2010 12:30 pm
Offline
you can download it only with FTP or Winbox, but you can try another approach - type "/export" without the file parameter. This will print the export on the telnet screen and you will be able to copy it with your mouse.
_________________
Top
 Profile
fewi
PostPosted: Wed Jul 14, 2010 3:35 pm
Offline
Code:
/file print detail where name=fileName
That will print file content on the console.
Top
 Profile
Display posts from previous:  Sort by
Post new topic Reply to topic  Page 1 of 1
 [ 5 posts ]
Board index » RouterOS » General
Users browsing this forum: Fran66 and 19 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB® Forum Software © phpBB Group
Karma functions powered by Karma MOD © 2007, 2009 m157y
