Hi
I have a run of approx 70 metres. Would an rb433 be able to run on an 18v 1 amp supply or should i Go for 24 or 48 v, using standard cat5e solid cable UTP.
The rb433 has a requirement of between 10 and 28 volts dc
Your voltage drop won't be more than 2 volts so you should be fine. 24vdc would also work well. You cannot use 48 volts without a dc/dc converter to drop the voltage under 28.Hi
