I've setup two RouterOS boxes - one in Europe and one in Asia, where the normal Internet latency is about 400 ms between the endpoints.
One of the routers is connected to Internet with PPPoE (MTU/MRU 1460). The other one has a direct ethernet connection to Internet.
Running the Mikrotik Bandwidth tester over a l2tp connection between the routers (ether2-pppoe-l2tp====l2tp-ether2) gives the full expected bandwidth of 10 Mbps (this is the subscribed bandwidth on the PPPoE-connected router), so this works better than expected..
But when I connect a Linux server to ether1 on each router, and copy a file using scp between the servers, the bandwidth is only getting up to 3 Mbps.
I have experimented with different MTU/MRU on both PPoE and L2TP configs, but it doesn't change things dramatically.
Anyone got an idea or explanation? Might it be the large latency (ie the SSH protocol used for the scp command is waiting for regular acks or something..)? Or am I missing something that I need to do on the LAN side of the routers to cater for the lower MxU's on the Internet side..?
