ataomega
how to disable firewall
Tue Dec 07, 2010 9:59 am
Hello All.
i'm almost new to mikrotik
i installed mikrotik on a server and configured VPN (pptp- l2tp) successfully
everything was ok.
but i go to web interface and enabled firewall (i think it was securing your server, customers and etc, external interface ...) i check all buttons and saved it.
now , no vpn user can connect, no winbox and no webbox can connect. but i have access to command line through vnc.
how should i disable firewall?
thanks in advanced
fewi
Re: how to disable firewall
Tue Dec 07, 2010 4:16 pm
/ip firewall filter disable [/ip firewall filter find]
That will disable all firewall filter rules. The same works on other sections, just replace the command path appropriately.
ataomega
Tue Dec 07, 2010 4:29 pm
hi. tnx for your reply. i just removed all rules and everything is ok. i configured rules again.
Users browsing this forum: aoravent, menyarito, phascogale, Soleous75 and 76 guests
