Thank's for your reply fewi, i have tried using mangle first to, :
/ip firewall mangle> add chain=prerouting protocol=tcp dst-port=80,443 action=mark
-packet new-packet-mark=test passthrough=yes
and in the simple queue i just add the packet marks based on mangle, but it's not work and when i browsing the web the speed is same, need advise please,
fewi, sorry, need more enlightment please about your second part explanation, can i just write the ip dst i want to limit when access it on the dst-address(simple queue) or i must put in the mangle and the mark the packet like the case above ?
If i can put the ip i want to limit when access it via dst-address(simple queue), it can't work on me, cause i have tested it.
Right now i setup the connection internet using web proxy mikrotik, is there any related that make my mangle rule not work?,
sorry about this question and thank's a lot.
