I look for some external radius for mikrotik that easy for use and config and support many site. Please suggesst to me.
Thanks.
I use FreeRADIUS/daloradius frontend. I dont bill for services, but daloradius makes management simple. Also use some triggers to update information in RADIUS from external sources. IE: Provisioning hardware for the VPN connections.fewi - re FreeRadius, good recommendation. But it does need a lot of time and work to make a usable front end for billing and user control. OK for geeks or those on a big budget to pay for a web developer! Anyone using DaloRadius?
I have told him, numerous times. I think there is a language problem as all I get is a repeat of what the software already does but no confirmation of an understanding of our problem, or indication of any possible future change!Viktor makes a good job
Thank you very much for your offer. I found out that MikroTik User Manager only seems to work with MikroTik Routers, so I would be very appreciated for a test account.If you want to try a fully licensed system, I am happy to give you login details for our test system where you can add your own AP and do your own tests. Contact me off-list (details below). I am also interested to see what Martín finds with his own tests. If I am wrong, I will happily test mine again!
