• MikroTik.com
  • RouterBOARD
  • User Meeting
  • Training
  • User Manual
  • Support
  • Downloads
  • Videos
Register |   * Login | HOME
View unanswered posts | View active topics
IP Queue on Mikrotik Hot spot DHCP  Page 1 of 1
 [ 7 posts ]  Post new topic Reply to topic
  Print view Previous topic | Next topic
Author Message
midnightman
 Post subject: IP Queue on Mikrotik Hot spot DHCP
PostPosted: Thu Feb 10, 2011 7:03 pm
Offline
hello,
I need to solve a simple problem. I have a mikrotik with enable hot spot. Everything works OK, but i neet queue on IP adrs. and I dont want to add all ips in network manually to queue. Is there a option to set queue for example 1mb/2mb on every IP on network range? (on DHCP) for example
IP 192.168.1.1 (Queue speed 1m/2m)
IP 192.168.1.2 (Queue speed 1m/2m)
IP 192.168.1.3 (Queue speed 1m/2m)
IP 192.168.1.4 (Queue speed 1m/2m)
without manually adds all 254 ips to queues? Thanks
Top
 Profile
marioclep
 Post subject: Re: IP Queue on Mikrotik Hot spot DHCP
PostPosted: Thu Feb 10, 2011 7:25 pm
Offline
Hi there!
You should try some of this: http://wiki.mikrotik.com/wiki/Manual:Queues_-_PCQ_Examples
Regards
_________________
Mario D. Clep
Ing. en Telecomunicaciones
MikroTik Certified Trainer
Top
 Profile
midnightman
PostPosted: Thu Feb 10, 2011 7:32 pm
Offline
If I understand...
/queue type add name="PCQ_download" kind=pcq pcq-rate=64000 pcq-classifier=dst-address
/queue type add name="PCQ_upload" kind=pcq pcq-rate=32000 pcq-classifier=src-address
every IP adr will get 32k/64k (Up/Dw) ? If I will have 20 online users on hot spot everyone will have only 32k/64k speed right?
Top
 Profile
Feklar
PostPosted: Thu Feb 10, 2011 7:50 pm
Offline
This is probably what you are looking for:
http://mum.mikrotik.com/presentations/U ... xWindt.pdf
Top
 Profile
midnightman
PostPosted: Thu Feb 10, 2011 8:08 pm
Offline
it looks good....Now I I know that I am only a beginer :D
Top
 Profile
marioclep
PostPosted: Thu Feb 10, 2011 8:34 pm
Offline
midnightman wrote:
If I understand...
Correcto!
_________________
Mario D. Clep
Top
 Profile
cdga12
PostPosted: Tue Apr 12, 2011 12:20 am
Offline
marioclep wrote:
midnightman wrote:
If I understand...
Correcto!
Hola Mario,
Soy Carlos, encantado, te he seguido con una documentación tuya que he encontrado y los dos videos al que haces referencia,
Estoy realizando mi Tesis, y consiste en un enlace wifi 11n mimo 2x2 para un proyecto de telemedicina en la selva peruana, con soporte de QoS, dispongo de equipos rb 433ah, y tarjetas r52hn,
Deseo configurar uns disciplina de colas con clases HTB con disciplinas SFQ para los servicios se videoconferencia y VoIP. además PCQ para el tercer tipo de tráfico que es descarga de internet,
He consultado la información de mikrotik y demás información. Pero no he podido aclararme, respecto a que debo configurar respecto al marcado de conexión y de los paquetes. además del uso del prerouting, fordware y postrouting
pregunta:?
1.- chain=prerouting, se usa para marcar el tráfico, solo en caso de enmascaramiento con nat?
2.- chain=fordware, se usa para marcar el tráfico, para el caso en que no tienes enmascaramiento?
3.- En que caso usaré, chain= postrouting
4.- Quiero configurar WMM en mikrotik, como debo hacerlo?, me podrias facilitar alguna documentación,
CARLOS DAVID GUERRA ANICAMA
cdga12@gmail.com
Te agradezco me puedas responder estimado Mario, recibe un cordial saludo y muchas gracias anticipadas,
Top
 Profile
Display posts from previous:  Sort by
Post new topic Reply to topic  Page 1 of 1
 [ 7 posts ]
Board index » RouterOS » General
Users browsing this forum: Bing [Bot], ffernandes, Google [Bot], hadyatef, hugleo, JonasJ and 18 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB® Forum Software © phpBB Group
Karma functions powered by Karma MOD © 2007, 2009 m157y
