Hello
I am going to connect with other isp with BGP
i am interesting will rb1100 will work for this task?
Traffic will be max 1 gbps
Regardless of packet size it shows that the RB1100 CPU get crushed when even just trying on ConTrack, add some firewall rules in and it runs @ 25% of what it can do with ConTrack off and no firewall rulesHow were the packet sizes distributed? If all packets were 1500 bytes, this test means very little.
Good morning - it is the same to each and every system, x86 or Routerboard - conntrack is, was and will be THE most expensive feature out there. So it has nothing to do with particular boardRegardless of packet size it shows that the RB1100 CPU get crushed when even just trying on ConTrack, add some firewall rules in and it runs @ 25% of what it can do with ConTrack off and no firewall rules
Get your x86 to run at 100% load without conntrack, then enable conntrack with some firewall rules, you will see similar impact. Only problem is to get that 100% load on current x86 . I know this from experience when most of my routers was Pentium 1 and 2, maybe 3x86 systems don't take as much of a hit as RB's and the RB1100 was pushed as a high-end router. Read around, the expectations of this RB were high from users and there are a few threads now asking why the RB1100 is struggling with what I would consider fairly basic setups
