restebanez
Serial port update rate
Thu Mar 17, 2011 1:44 pm
Hi.
I'm using the RB411 serial port mapped to a TCP port.
Everything is fine if I send data from the TCP port to the serial port (form My PC the the external sensor). But when I send data from the Serial Port to the TCP port , information is not send inmediatly. I seems RB411 fills up a buffer and only sends data about 5 times per second....
In my application I would like to view the sensor data (rs232 sensor @ 115200 bauds) at higher frecuency (in fact it works at 300 hz).
Is there a way to change this behaviour ?
Thank you in advance.
Users browsing this forum: Majestic-12 [Bot], snoge and 22 guests
