Since I saw this http://www.mikrotik.com/download/share/hu11.pdf I was very excited about new products.This is definately great news. Can we get an idea of what the cost of these products would be? I'm highly interested in Groove and Omnitik....
Joined: Fri May 28, 2004 10:04 am Posts: 16951 Location: Riga, Latvia
ilius168 wrote:
What is the power source for RB 750UP?
what if a device such as RB 800 which needs 48V? Will it support 802.3af in the future?
no, 802.3af is not supported, it outputs the same as it gets in from jack, so 24V basically. it can only output 600mA per port, so calculate accordingly. 48V is not possible, this is more optimized for SXT, RB711 etc.
RB750UP was/is planned to be availlable this month - is the timeline still actual? The datasheet exists? Are there shielding/grounding on the eth. ports?
Thank for reply, hopfly the timeline is still reachable . Previously:
- Same as regular RB750 + USB port + 24V Power Output on four ports * Controllable PoE out * SNMP support * Voltage and current monitors + Can power PoE capable devices + Less cables and PoE injectors - Available in May
Users browsing this forum: Google [Bot], ojeysky and 14 guests
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot post attachments in this forum
