Here is my config.
I hope it's safe to present.
I have 2 problems.
I can't get port forwarding to work with pppoe-out1.
port forwarding is working fine when trying to connect to wlan1.
I'm not sure that the load balancing is working as I notice I am always going out over the DHCP wan port.
Any suggestions would be very appreciated.
Thanks in advance,
Juniorsa
[admin@MikroTik] > /export
# jan/02/1970 11:48:07 by RouterOS 5.2
# software id = K69D-Y4KV
add admin-mac=00:00:00:00:00:00 ageing-time=5m arp=enabled auto-mac=yes disabled=no forward-delay=15s l2mtu=1522 max-message-age=20s mtu=1500 name=LAN priority=0x8000 \
protocol-mode=none transmit-hold-count=6
set 0 arp=enabled auto-negotiation=yes disabled=no full-duplex=yes l2mtu=1526 mac-address=00:0C:42:59:27:7C mtu=1500 name=wlan1 speed=100Mbps
set 1 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no full-duplex=yes l2mtu=1522 mac-address=00:0C:42:59:27:7D master-port=none mtu=1500 name=\
wlan2 speed=100Mbps
set 2 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no full-duplex=yes l2mtu=1522 mac-address=00:0C:42:59:27:7E master-port=none mtu=1500 name=\
ether3 speed=100Mbps
set 3 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no full-duplex=yes l2mtu=1522 mac-address=00:0C:42:59:27:7F master-port=none mtu=1500 name=\
ether4 speed=100Mbps
set 4 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no full-duplex=yes l2mtu=1522 mac-address=00:0C:42:59:27:80 master-port=none mtu=1500 name=\
ether5 speed=100Mbps
/interface ethernet switch
set switch1 mirror-source=none mirror-target=none name=switch1
set default authentication-types="" eap-methods=passthrough group-ciphers="" group-key-update=5m interim-update=0s management-protection=disabled \
management-protection-key="" mode=none name=default radius-eap-accounting=no radius-mac-accounting=no radius-mac-authentication=no radius-mac-caching=disabled \
radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username static-algo-0=none static-algo-1=none static-algo-2=none static-algo-3=none static-key-0="" \
static-key-1="" static-key-2="" static-key-3="" static-sta-private-algo=none static-sta-private-key="" static-transmit-key=key-0 supplicant-identity=MikroTik \
tls-certificate=none tls-mode=no-certificates unicast-ciphers="" wpa-pre-shared-key="" wpa2-pre-shared-key=""
/ip hotspot profile
set default dns-name="" hotspot-address=0.0.0.0 html-directory=hotspot http-cookie-lifetime=3d http-proxy=0.0.0.0:0 login-by=cookie,http-chap name=default rate-limit="" \
smtp-server=0.0.0.0 split-user-domain=no use-radius=no
/ip hotspot user profile
set default idle-timeout=none keepalive-timeout=2m name=default shared-users=1 status-autorefresh=1m transparent-proxy=no
/ip ipsec proposal
set default auth-algorithms=sha1 disabled=no enc-algorithms=3des lifetime=30m name=default pfs-group=modp1024
add name=pool1 ranges=192.168.5.100,192.168.5.200
add name=dhcp_pool1 ranges=192.168.5.100-192.168.5.200
add address-pool=dhcp_pool1 authoritative=after-2sec-delay bootp-support=static disabled=no interface=LAN lease-time=3d name=dhcp1
/port
set 0 baud-rate=auto data-bits=8 flow-control=none name=serial0 parity=none stop-bits=1
/ppp profile
set default change-tcp-mss=yes name=default only-one=default use-compression=default use-encryption=default use-mpls=default use-vj-compression=default
set default-encryption change-tcp-mss=yes name=default-encryption only-one=default use-compression=default use-encryption=yes use-mpls=default use-vj-compression=default
/interface pppoe-client
add ac-name="" add-default-route=yes allow=pap,chap,mschap1,mschap2 dial-on-demand=no disabled=no interface=wlan2 max-mru=1452 max-mtu=1452 mrru=disabled name=pppoe-out1 \
password=xxxxx profile=default service-name="" use-peer-dns=no user=xxxx
/queue type
set default kind=pfifo name=default pfifo-limit=50
set ethernet-default kind=pfifo name=ethernet-default pfifo-limit=50
set wireless-default kind=sfq name=wireless-default sfq-allot=1514 sfq-perturb=5
set synchronous-default kind=red name=synchronous-default red-avg-packet=1000 red-burst=20 red-limit=60 red-max-threshold=50 red-min-threshold=10
set hotspot-default kind=sfq name=hotspot-default sfq-allot=1514 sfq-perturb=5
set default-small kind=pfifo name=default-small pfifo-limit=10
/routing bgp instance
set default as=65530 client-to-client-reflection=yes disabled=no ignore-as-path-len=no name=default out-filter="" redistribute-connected=no redistribute-ospf=no \
redistribute-other-bgp=no redistribute-rip=no redistribute-static=no router-id=0.0.0.0 routing-table=""
/routing ospf instance
set default disabled=no distribute-default=never in-filter=ospf-in metric-bgp=auto metric-connected=20 metric-default=1 metric-other-ospf=auto metric-rip=20 metric-static=\
20 name=default out-filter=ospf-out redistribute-bgp=no redistribute-connected=no redistribute-other-ospf=no redistribute-rip=no redistribute-static=no router-id=\
0.0.0.0
/routing ospf area
set backbone area-id=0.0.0.0 disabled=no instance=default name=backbone type=default
/snmp
set contact="" enabled=no engine-id="" location="" trap-target=0.0.0.0 trap-version=1
/snmp community
set public address=0.0.0.0/0 authentication-password="" authentication-protocol=MD5 encryption-password="" encryption-protocol=DES name=public read-access=yes security=\
none write-access=no
/system logging action
set memory memory-lines=100 memory-stop-on-full=no name=memory target=memory
set disk disk-file-count=2 disk-file-name=log disk-lines-per-file=100 disk-stop-on-full=no name=disk target=disk
set echo name=echo remember=yes target=echo
set remote bsd-syslog=no name=remote remote-port=514 syslog-facility=daemon syslog-severity=auto target=remote
/system routerboard settings
set baud-rate=115200 boot-delay=2s boot-device=nand-if-fail-then-ethernet boot-protocol=bootp cpu-frequency=300MHz enable-jumper-reset=yes enter-setup-on=any-key \
force-backup-booter=no
/user group
add name=read policy=local,telnet,ssh,reboot,read,test,winbox,password,web,sniff,sensitive,api,!ftp,!write,!policy
add name=write policy=local,telnet,ssh,reboot,read,write,test,winbox,password,web,sniff,sensitive,api,!ftp,!policy
add name=full policy=local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,password,web,sniff,sensitive,api
add bridge=LAN disabled=no edge=auto external-fdb=auto horizon=none interface=ether3 path-cost=10 point-to-point=auto priority=0x80
add bridge=LAN disabled=no edge=auto external-fdb=auto horizon=none interface=ether4 path-cost=10 point-to-point=auto priority=0x80
add bridge=LAN disabled=no edge=auto external-fdb=auto horizon=none interface=ether5 path-cost=10 point-to-point=auto priority=0x80
/interface bridge settings
set use-ip-firewall=no use-ip-firewall-for-pppoe=no use-ip-firewall-for-vlan=no
set wlan2
set ether3
set ether4
set ether5
set switch1_cpu
/interface l2tp-server server
set authentication=pap,chap,mschap1,mschap2 default-profile=default-encryption enabled=no max-mru=1460 max-mtu=1460 mrru=disabled
/interface ovpn-server server
set auth=sha1,md5 certificate=none cipher=blowfish128,aes128 default-profile=default enabled=no keepalive-timeout=60 mac-address=FE:84:17:5A:01:B4 max-mtu=1500 mode=ip \
netmask=24 port=1194 require-client-certificate=no
/interface pptp-server server
set authentication=mschap1,mschap2 default-profile=default-encryption enabled=no keepalive-timeout=30 max-mru=1460 max-mtu=1460 mrru=disabled
/interface sstp-server server
set authentication=pap,chap,mschap1,mschap2 certificate=none default-profile=default enabled=no keepalive-timeout=60 max-mru=1500 max-mtu=1500 mrru=disabled port=443 \
verify-client-certificate=no
/interface wireless align
set active-mode=yes audio-max=-20 audio-min=-100 audio-monitor=00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 frame-size=300 frames-per-second=25 receive-all=no ssid-all=\
no
/interface wireless sniffer
set channel-time=200ms file-limit=10 file-name="" memory-limit=10 multiple-channels=no only-headers=no receive-errors=no streaming-enabled=no streaming-max-rate=0 \
streaming-server=0.0.0.0
/interface wireless snooper
set channel-time=200ms multiple-channels=yes receive-errors=no
/ip accounting
set account-local-traffic=no enabled=no threshold=256
/ip accounting web-access
set accessible-via-web=no address=0.0.0.0/0
add address=192.168.5.1/24 comment="added by setup" disabled=no interface=ether3 network=192.168.5.0
/ip dhcp-client
add add-default-route=yes default-route-distance=0 disabled=no interface=wlan1 use-peer-dns=yes use-peer-ntp=yes
/ip dhcp-server config
set store-leases-disk=5m
add address=192.168.5.0/24 dns-server=192.168.5.1,192.168.6.1 gateway=192.168.5.1
set allow-remote-requests=yes cache-max-ttl=1w cache-size=2048KiB max-udp-packet-size=512 servers=192.168.5.1,192.168.6.1
/ip dns static
add address=192.168.5.4 disabled=no name=miffy.dido.ca ttl=1d
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s tcp-close-wait-timeout=10s tcp-established-timeout=1d tcp-fin-wait-timeout=10s \
tcp-last-ack-timeout=10s tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
/ip firewall mangle
add action=mark-connection chain=input disabled=no in-interface=wlan1 new-connection-mark=wlan1_conn passthrough=yes
add action=mark-connection chain=input disabled=no in-interface=wlan2 new-connection-mark=wlan2_conn passthrough=yes
add action=mark-routing chain=output connection-mark=wlan1_conn disabled=no new-routing-mark=to_wla1 passthrough=yes
add action=mark-routing chain=output connection-mark=wlan1_conn disabled=no new-routing-mark=to_wla2 passthrough=yes
add action=masquerade chain=srcnat disabled=no out-interface=pppoe-out1
add action=masquerade chain=srcnat disabled=no out-interface=wlan1
add action=dst-nat chain=dstnat disabled=no dst-port=22 in-interface=wlan1 protocol=tcp to-addresses=192.168.5.4 to-ports=22
add action=dst-nat chain=dstnat disabled=no dst-port=80 in-interface=wlan1 protocol=tcp to-addresses=192.168.5.4 to-ports=80
add action=dst-nat chain=dstnat disabled=no dst-port=25 in-interface=wlan1 protocol=tcp to-addresses=192.168.5.4 to-ports=25
add action=dst-nat chain=dstnat disabled=no dst-port=53 in-interface=wlan1 protocol=udp to-addresses=192.168.5.4 to-ports=53
add action=dst-nat chain=dstnat disabled=no dst-port=22 in-interface=pppoe-out1 protocol=tcp to-addresses=192.168.5.4 to-ports=22
add action=dst-nat chain=dstnat disabled=no dst-port=80 in-interface=pppoe-out1 protocol=tcp to-addresses=192.168.5.4 to-ports=80
add action=dst-nat chain=dstnat disabled=no dst-port=25 in-interface=pppoe-out1 protocol=tcp to-addresses=192.168.5.4 to-ports=25
add action=dst-nat chain=dstnat disabled=no dst-port=53 in-interface=pppoe-out1 protocol=udp to-addresses=192.168.5.4 to-ports=53
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061
set pptp disabled=no
/ip hotspot service-port
/ip neighbor discovery
set wlan1 discover=yes
set wlan2 discover=yes
set ether3 discover=yes
set ether4 discover=yes
set ether5 discover=yes
set pppoe-out1 discover=no
set LAN discover=yes
/ip proxy
set always-from-cache=no cache-administrator=webmaster cache-hit-dscp=4 cache-on-disk=no enabled=no max-cache-size=none max-client-connections=600 max-fresh-time=3d \
max-server-connections=600 parent-proxy=0.0.0.0 parent-proxy-port=0 port=8080 serialize-connections=no src-address=0.0.0.0
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=wlan1 routing-mark=to_wla1 scope=30 target-scope=10
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=wlan2 routing-mark=to_wla2 scope=30 target-scope=10
add check-gateway=ping disabled=no distance=1 dst-address=0.0.0.0/32 gateway=wlan2,wlan1 scope=30 target-scope=10
/ip service
set telnet disabled=no port=23
set ftp disabled=no port=21
set www disabled=no port=8080
set ssh disabled=no port=222
set www-ssl certificate=none disabled=yes port=443
set api disabled=yes port=8728
set winbox disabled=no port=8291
/ip socks
set connection-idle-timeout=2m enabled=no max-connections=200 port=1080
/ip ssh
set forwarding-enabled=no
/ip traffic-flow
set active-flow-timeout=30m cache-entries=4k enabled=no inactive-flow-timeout=15s interfaces=all
/ip upnp
set allow-disable-external-interface=yes enabled=no show-dummy-rule=yes
/mpls
set dynamic-label-range=16-1048575 propagate-ttl=yes
/mpls interface
add disabled=no interface=all mpls-mtu=1508
/mpls ldp
set distribute-for-default-route=no enabled=no hop-limit=255 loop-detect=no lsr-id=0.0.0.0 path-vector-limit=255 transport-address=0.0.0.0 use-explicit-null=no
/port firmware
set directory=firmware
/ppp aaa
set accounting=yes interim-update=0s use-radius=no
/queue interface
set wlan1 queue=ethernet-default
set wlan2 queue=ethernet-default
set ether3 queue=ethernet-default
set ether4 queue=ethernet-default
set ether5 queue=ethernet-default
/radius incoming
set accept=no port=3799
/routing bfd interface
set all disabled=no interface=all interval=0.2sec min-rx=0.2sec multiplier=5
/routing mme
set bidirectional-timeout=2 gateway-class=none gateway-keepalive=1m gateway-selection=no-gateway origination-interval=5s preferred-gateway=0.0.0.0 timeout=1m ttl=50
/routing rip
set distribute-default=never garbage-timer=2m metric-bgp=1 metric-connected=1 metric-default=1 metric-ospf=1 metric-static=1 redistribute-bgp=no redistribute-connected=no \
redistribute-ospf=no redistribute-static=no routing-table=main timeout-timer=3m update-timer=30s
/store
add disabled=no disk=system name=web-proxy1 type=web-proxy
/system clock
set time-zone-name=manual
/system clock manual
set dst-delta=+00:00 dst-end="jan/01/1970 00:00:00" dst-start="jan/01/1970 00:00:00" time-zone=+00:00
/system console
add disabled=no port=serial0 term=vt102
/system health
set
/system identity
set name=MikroTik
/system logging
add action=memory disabled=no prefix="" topics=info
add action=memory disabled=no prefix="" topics=error
add action=memory disabled=no prefix="" topics=warning
add action=echo disabled=no prefix="" topics=critical
/system note
set note="" show-at-login=yes
/system ntp client
set enabled=no mode=broadcast primary-ntp=0.0.0.0 secondary-ntp=0.0.0.0
/system resource irq
set 0 cpu=auto
set 1 cpu=auto
set 2 cpu=auto
set 3 cpu=auto
set 4 cpu=auto
/system upgrade mirror
set check-interval=1d enabled=no primary-server=0.0.0.0 secondary-server=0.0.0.0 user=""
/system watchdog
set auto-send-supout=no automatic-supout=yes no-ping-delay=5m watch-address=none watchdog-timer=yes
/tool bandwidth-server
set allocate-udp-ports-from=2000 authenticate=yes enabled=yes max-sessions=100
/tool e-mail
set address=0.0.0.0 from=<> password="" port=25 user=""
/tool graphing
set page-refresh=300 store-every=5min
/tool mac-server
/tool mac-server ping
set enabled=yes
/tool sms
set allowed-number="" channel=0 keep-max-sms=0 receive-enabled=no secret=""
/tool sniffer
set file-limit=10 file-name="" filter-address1=0.0.0.0/0:0-65535 filter-address2=0.0.0.0/0:0-65535 filter-protocol=all-frames filter-stream=yes interface=all memory-limit=\
10 memory-scroll=yes only-headers=no streaming-enabled=no streaming-server=0.0.0.0
/user aaa
set accounting=yes default-group=read interim-update=0s use-radius=no
[admin@MikroTik] >
