Lakis
Long time Member
Long time Member
invalid value for argument address!!!!
Fri Jun 17, 2011 1:24 pm
ROS 4.17 every 1-2 days DNS stop working
when I ping google.com
[Mikrotik@] > ping www.google.com
action timed out - try again, if error continues contact MikroTik support and send a supout file (13)
after reboot all back to normal..
Pls for help how can I avoid this problem
Tnx...
fewi
Re: invalid value for argument address!!!!
Fri Jun 17, 2011 3:50 pm
Did you send support a supout.rif? When that error comes up the router is saying "hi you found a bug". To avoid this problem help Mikrotik fix the bug by sending them the requested information.
Specific answers require specific questions. When in doubt, post the output of "/ip address print detail", "/ip route print detail", "/interface print detail", "/ip firewall export", and an accurate network diagram.
Users browsing this forum: SteloNLD and 21 guests
