Tue Jun 21, 2011 9:58 pm
I am sending the supporting supout files to support, but hoping someone else has ran into this and found a workaround. We have hotspot running with mac-authentication via radius on a bridge interface. We also have pppoe services running on the same interface. Both services pull IP's from the same pool(s). We are not using universal client. This bug has been verified on 5.0 and 5.4, don't use 5.1,5.2, or 5.3, but am assuming (yes... i know...) that this problem exists there as well. After an indeterminate period of time, pppoe sessions stop passing traffic. If I disable the hotspot server and re-enable it, pppoe sessions start passing traffic again, no need to reconnect them or anything, it just fixes the issue. This occurs daily.
