Yukado
Problem with QoS and winbox
Mon Jun 27, 2011 2:13 pm
I want to configure QoS rules that appear in this site:
http://wiki.mikrotik.com/wiki/Traffic_P ... lemetation
But I have a problem. When I enable the bridge, I can't connect to winbox.
I have few experience using Mikrotik.
I hope you can help me
Thanks for your time.
Egate
Long time Member
Long time Member
Re: Problem with QoS and winbox
Mon Jun 27, 2011 10:51 pm
Give bridge the ip, also possible to access router board with winbox.
Yukado
Wed Jun 29, 2011 1:55 pm
I can't access using winbox.
How can I get the bridge's ip?
Caci99
Wed Jun 29, 2011 2:05 pm
What type of routerboard are you using? If it has a serial port you can connect to it
through this port.
Have you tried to connect using mac-address with winbox, instead of IP address?
Egate
Long time Member
Long time Member
Wed Jun 29, 2011 3:00 pm
Do as Casi say, was also talking about mac in winbox. To give bridge the ip, you just select the bridge as the interlace when you create ip.
Yukado
Fri Jul 01, 2011 1:07 pm
I am using a PC like Mikrotik Router. I am using Ethernet port to connect.
I have seen that the ip address change to another network when I enable the bridge. For example, it changed from 192.168.1.xx to 192.168.0.xx.
Maybe you can see the problem now.
Egate
Long time Member
Long time Member
Fri Jul 01, 2011 7:56 pm
Pc, also has a serial port, will work with telnet, read manual on howto. You can use mac instead if ip to connect onto mikrotik with winbox, on Ethernet port.
Assign ip to bridge, normally bridge take Ethernet port ip automatic, but better to assign. Only assign bridge the ip, not any of the ports using bridge, like your Ethernet port.
Yukado
Wed Jul 06, 2011 12:50 pm
How can I assign the ip to the bridge?
Caci99
Wed Jul 06, 2011 1:37 pm
From winbox, just double click on the address and assign the interface
on the drop down menu interface in that window.
From terminal:
print
after command print you will see the ip address you want to assign on the bridge interface
and let's suppose that it has a number assigned "0", then:
set 0 interface=bridge1
Users browsing this forum: Bing [Bot], chronos31337, dewitpj, maldridge and 64 guests
