Following this logic, you could post this problem in all other topics. Make a separate topic about your problem, and let us decide if this problem is similar to some other problem. This topic is about excess logging about ethernet status. you have wireless problems. Completely different things.
Normis Can i ask how do assume when i said the issue i had with ethernet side of the ptp link where i could not login to the board using 5.4/5.5 was
"wireless problem" all indications to me it was ethernet connectivity issue and not wireless?,
Yes you maybe correct it may not have had any thing in common with port flapping issue apart from using the same software version and in the distant future when we look back at issues like port flapping and may have discovered it was only caused by just "X" but until then <?>,
Remember MT keeps telling us they cannot reproduce some of the issues and as such MT are at a disadvantage as they do not know first hand if the "hotfix" will work but release for select users to test,
Would it not be a more serious problem for MT if no feedback what so ever was posted on the forum but just endless emails direct to support demanding a fix for every issue, as in life technical issues are not a simple black or white but a lot of grey area sometimes, if it was simple - issues would be quickly addressed - right?
