firewallrule
Printer Routing
Fri Aug 05, 2011 10:04 pm
Can some help me figure out the best way to make this work?
From the diagram below, i want Host A and Host B to be printing through Window xp that share the internet connection before the Mikrotik.
Detail explanation will be highly welcome.
Am not good in routing traffic.
dog
Re: Printer Routing
Sat Aug 06, 2011 6:51 pm
Where is your problem?
Add the IPs on the MT:
/ip addr add=192.168.0.2/24 int=ether1
/ip addr add=192.168.2.1/24 int=ether2
Add the internet route:
/ip route add dst=0.0.0.0/0 gateway=192.168.0.1
Set the MT as default gateway on Host A and Host B.
Then on the xp box you either need to set a reverse route or use NAT on the MT:
/ip firew nat add chain=srcnat out-interf=ether1 action=masq
firewallrule
Re: Printer Routing
Sat Aug 06, 2011 9:15 pm
what i want is for host A and B to be able to print document through the printer machine installed to the window xp.
They can surf the internet effectively without issue.
firewallrule
Re: Printer Routing
Mon Aug 08, 2011 1:37 pm
Can someone respond to my request please.
Davis
Re: Printer Routing
Mon Aug 08, 2011 1:51 pm
Probably you need to connect to printer machine by IP address not by computername.
Can you open \\192.168.0.1\ on Host A or Host B?
firewallrule
Re: Printer Routing
Mon Aug 08, 2011 9:56 pm
no
Host A and B are not connected directly to window xp.
Davis
Re: Printer Routing
Tue Aug 09, 2011 2:09 am
Do you have firewall on your Mikrotik that blocks access to File and Printer Sharing on printer computer?
If not, you should be able to access shares on that machine via the router.
firewallrule
Re: Printer Routing
Tue Aug 09, 2011 6:44 pm
Yes.
But how can it be allowed
fewi
Re: Printer Routing
Tue Aug 09, 2011 6:49 pm
Don't drop it? By default the firewall permits all packets. So if the packets are getting dropped, they're getting dropped because you told the firewall to do so.
If you need specific help with your specific firewall configuration - that's going to be impossible unless you share your firewall configuration.
Users browsing this forum: Bing [Bot], vesuviustreamline and 188 guests
