Hi huys
Using the diagram below
I have router 1 & Router 2
Router 1 connects to the Internet while Router 2 connect to the rest of my network
The two Routers are connected to each other over 2-interfaces.
The Problem
I want 10.4.1.0/24 & 10.6.1.0/24 traffic to reach router 1 via 10.10.10.4/30 network while
10.5.1.0/24 reach Router1 via 10.10.10.8/30 network
Things i have tried
On Router 1, using static routing, i have specified which interface handles which subnet
On Router 2,
1 Mark packet from each subnet with a routing mark
2 Add a default route for each of the routing marks
I actually use this tutorial http://wiki.mikrotik.com/wiki/Load_Bala ... e_Gateways but I did not do the masqurading aspect. Maybe thats why the whole thing did not work.
Pls I need help, i must not masquerade because one of the interfaces on Router 1 runs Hotspot which needs Client IP.
Pls what else can I try.
