w0lt
Long time Member
Long time Member
Re: RouterOS v5.7 released
Wed Sep 21, 2011 1:38 am
No DHCPv6 :( Booooooooooooo
So whats is the plan for DHCPv6 now ?
And what happened to Betas ? Now we just get final releases ?
IPv6
Starting from v5.8 RouterOS supports IPv6 prefix delegation according to RFC 3633.
DHCPv6 server works in parallel with regular DHCP server when address-pool6 option is set.
DHCPv6 uses following options:
authoritative
lease-time
address-pool6
interface
name
Looks like it might be around the corner...
-tp
jandafields
Wed Sep 21, 2011 2:12 am
Betas??? You mean the releases WAY BACK before RC1? v5 is no longer in beta.
Or, are you talking about, for example, the pre-release of v5.8 that some of us are using?
omega-00
Wed Sep 21, 2011 4:50 am
Feel free to use http://bugs.mikrotik-routeros.com/ to post any major issues you have with specific releases and provide as much information as you can about how to replicate these.
Seeing as that is not an official Mikrotik site, I don't see how it is any better than placing bugs on this forum. Mikrotik is much more likely to see bugs written here than on some external site.
It's an ordered list of bugs affecting different versions and if they're known to be resolved or not, if you'd rather have to search the forums to find any confirmed bugs before upgrading you're welcome to do so, however the solution I've offered is something that could potentially become incredibly useful with more input.
It's not intended to be submitted to mikrotik, bugs that are placed there have already been ticketed to support, we're simply keeping track of them so other can benefit knowing what issues are outstanding.
normis
Wed Sep 21, 2011 8:48 am
janisk
Wed Sep 21, 2011 8:51 am
it was cleary stated that dhcpv6-pd will not be here no sooner than 5.8
gluetea
Wed Sep 21, 2011 9:04 am
I have RB 450G and RB 493AH, only used it for loadbalancing and traffic shaping, no hotspot/wireless/ip6.
Mostly use Queue and /ip route, ROS 5.7 stable and got less cpu load than before version.
But old problem port/ether flapping still happening when i set my RB493AH using PPPoE (Adsl modem Bridge mode), connect and disconnect after 3-4minute, but if i set mikrotik to non PPPoE/NAT only (Adsl Modem TP-Link 8817 at PPPoE mode) work perfect. So i tried test using diffrent modem D-link 526b (broadcom chip) at Bridge mode and work good. I think the problem was TP-Link 8817 (Trend Chip) after 3 same modem tested.
I hope next ROS will fix compatibility issue with some adsl modem chipset.
taduikis
Wed Sep 21, 2011 9:57 am
Are there any more info about this problem? After upgrade to 5.7 I am experiencing ether1 problems. The link goes up and down randomly, sometimes it registers at only 10mbps half-duplex, then suddenly goes down. Physically nothing has been changed or touched, so there are very little chance it could be network adapter problem or something of coincidence. And that routerboard is mounted on a mast, that I would have to disassemble to bring it down. I really don't want to do that just for the screwdriver trick.
Today first time ever I have downgraded ROS, but unfortunately in 5.6 the problem remains.
Everything is fine until some traffic start to run over the bridge. Ethernetport becomes unavailable. Just dead.
Power cycle does not bring it back.
I have to resets config with the screwdriver manner, after that rb411 boots up normal and works again in basic config.
Second attempt, setup my wanted config now in 5.6. Works like a charm. After a while update to 5.7 again, router keeps on running. Put some traffic over it, Ethernet port becomes dead.
So their is definitely a bug in 5.7 that has to do with the bridge function.
I use the board now with 5.6 which is proven to be fine, also on bridges (I have some config similar like the one prescribed in my backhauls and they run with heavy traffic already for months.)
I am SOO happy you made an alert on this bug. If not and I would have started to implement 5.7 on my network it would have brought it almost completely down! :shock:
R.
alexspils
Wed Sep 21, 2011 11:21 am
Hello!!!
What about GSO/TSO/LRO in ROS?
http://en.wikipedia.org/wiki/Large_segment_offload
janisk
Wed Sep 21, 2011 12:00 pm
that is good for data source when sending out data. Router usually received already segmented data and all it has to do is route/filter these packets. Or i have misunderstood your request completely.
Xymox
Wed Sep 21, 2011 12:36 pm
Sorry my bad :( Im just impatient.. Plus not checking in and keeping up with the forum as much as I should..
Doesnt a "pre-release" count as a Beta ? If there are upcoming versions of the OS it would be cool if they were public beta..
normis
Wed Sep 21, 2011 12:40 pm
RouterOS example life cycle:
v4beta1
v4beta2
v4rc1
v4rc2
v4.0
v4.1
v4.2 (internal build, somtimes given to specific user for testing)
v4.2 (regular build, public)
v4.3
v5beta1
agenovez
Re: RouterOS v5.7 released NO command "routerboard"
Wed Sep 21, 2011 5:44 pm
Hello, I upgraded the routerboard 433AH to the lastest verison 5.7, but I can´t find the command
/system routerboard print
I gives me an error that shows "routerboard" isnt recognized.
It is weird because there is no problem with updated 411AH to 5.7, it shows this command.
Thanks for any help, maybe a bug?
Andres
taduikis
Wed Sep 21, 2011 7:55 pm
Sorry, false alarm. Problem was in the cable.
oeyre
Thu Sep 22, 2011 2:36 am
Not mentioned in changelog however the issue I was having with interface names when doing a configuration reset seem to be fixed.
janisk
Thu Sep 22, 2011 9:23 am
Andres
under '/system package' check if you have routerboard package installed. Most probably it is not.
Jeeves
Thu Sep 22, 2011 11:14 am
:( No dhcpv6...
It would be cool if Mikrotik had some kind of bugtracker, wouldn't it?
Normis has said this is planned for 5.8, I'm planning on holding him to that!
The bugtracker, or dhcpv6? :)
janisk
Thu Sep 22, 2011 11:18 am
dhcpv6-PD and that is being tested
Jeeves
Thu Sep 22, 2011 11:23 am
I would happily help with the testing!
janisk
Thu Sep 22, 2011 11:24 am
maybe later on. ATM we can manage.
Babek
Thu Sep 22, 2011 10:07 pm
does anyone noticed strange behavior of ethernet interfaces. 3 links with 5.7 routeros and i noticed after couple of hours, days ether port stops to transmit ip transmission. Seems connected but can only access through wireless link or not sure if mac-telnet would work but for sure IP ping from another one directly connected mikrotik doesn't work. Restarting interfaces and enable/disable IP doesn't solve the problem only reboot - routeros 5.7 and firmware 2.36
I have 8 routerboards with this firmware 435G, 433AH and 450G - and on 433AH and 435 transmission on ethernet stops afetr stometime. part of them with ospf part with bridge and vpls tunnel without ospf - .
Pawel
Ripper
Fri Sep 23, 2011 1:49 am
Should I apply multi-queue-ethernet-default to each simple queue to to advance and Total if I shaping by ip by general rule?
Or its just enough to apply to interface.
WirelessRudy
Fri Sep 23, 2011 2:37 am
Pawel
Well, there is definitely something going on with the Ethernet interfaces. Have you tried this: http://forum.mikrotik.com/viewtopic.php ... 41#p282141
Maybe downgrading of the firmware would help you?
Please try and let us know. If it does help, definitely report it to MT support. I start to think more and more in a direction indeed the firmware is part of the many problems we still see randomly around with Ethernet interfaces.
If several users can confirm downgrading is solving the problem MT can figure out where the difference is in-between the different versions and patch the bug.
janisk
Fri Sep 23, 2011 9:07 am
apply it on interface that has several tx/rx queues displayed in '/system resource irq' other way it will not bring you any improvement.
hapi
Fri Sep 23, 2011 9:46 am
upgrade from v5.6 to v5.7. More on SXT devices
zervan
Fri Sep 23, 2011 10:55 am
I can confirm that on my SXTs. What was the default state? I don't have any SXT on my eyes, so I can't experiment, but I'd like to have functional indicator of signal strength.
hapi
Fri Sep 23, 2011 11:09 am
[Ticket#2011082066000161] memory is full
problem continues on all SXT with active OSPF
murray654
Fri Sep 23, 2011 1:59 pm
yesterday 22 sept I had 5mib free RAM
23 Sept 13h59 I have 4mib free
23 Sept 17h24 I have 3.5mib free RAM
Pattern is as time passes more RAM used, less RAM free.
My router is the RB750.
Ripper
Fri Sep 23, 2011 7:48 pm
What does it mean ?
2Core Cpu
trol4o
Sat Sep 24, 2011 12:57 pm
*) userman - show overall totals, show user totals if user has more
than one entry;
Can anyone explain what exactly is meant by that - I've installed the new version at both my radius server with userman package and my hotspot servers, and still no luck - userman does not keep ant statistics - once a profile expires, userman forgets all about it - keeps log of sessions, but is unable to display start time, end time, till time and so on. Instead it just displays "unknown", which bugs me to no end.
I have to account many profiles each month - how many profiles from a given period are activated, when are they expired, so on. Right now the only way to do it is to click each and every one of them separately, look at sessions log and write it down. And they are THOUSANDS. The only relieve I had was for about a month - some of the accounts displayed properly at "till time" column. Once I upgraded from 5.5 to 5.6 though, they stopped doing it and I went back to counting one by one.
I'm waiting for a fix to accounting for almost an year, and still no luck - is it so hard to fix a few MAJOR userman bugs? The only reason to buy a Level 6 license is to use Usermanager package with no limits - well, I bought several of them, and still don't have anything stable and working for my money.
tomaskir
Trainer
Trainer
Sat Sep 24, 2011 2:34 pm
I upgraded a RB1200 today and its affected by constant 100% CPU usage as well.
Anything I can do?
jandafields
Sat Sep 24, 2011 5:02 pm
Anything I can do?
Make sure you don't have DHCP enabled on any unused interfaces. I read it should be fixed in 5.8
tomaskir
Trainer
Trainer
Sat Sep 24, 2011 5:53 pm
Anything I can do?
I have DHCP enabled on about 20 vlan interfaces, and 1 DHCP disabled on a vlan interface.
Define what you mean by "unused interface" pls :)
jandafields
Sat Sep 24, 2011 6:06 pm
Anything I can do?
According to Normis from Mikrotik:
"remember also that in v5.7 there is a DHCP server bug, where it causes high resource usage if it's on a disabled interface. this is fixed in v5.8"
tomaskir
Trainer
Trainer
Sat Sep 24, 2011 6:07 pm
multiquote removed, making this post 75% more easier to read
According to Normis of Mikrotik:
Yup, enabling the disabled DHCP on a fully functioning vlan interface fixed it.
Chupaka
Sat Sep 24, 2011 7:35 pm
What does it mean ?
2Core Cpu
seems like your both NICs use the same IRQ... bad thing =)
anyway, 'several tx/rx queues' means this:
[admin@MikroTik] > /sys resource irq print without-paging
 # IRQ USERS                                                        CPU ACTIVE-CPU      COUNT
13  60 ether2                                                         1          1          1
14  61 eth1-rx-0                                                      1          1      83125
15  62 eth1-rx-1                                                      1          1      89667
16  63 eth1-rx-2                                                      1          1      26846
17  64 eth1-rx-3                                                      2          2      87094
18  65 eth1-tx-0                                                      1          1       9622
19  66 eth1-tx-1                                                      1          1      30122
20  67 eth1-tx-2                                                      1          1      19775
21  68 eth1-tx-3                                                      2          2      19630
22  69 eth2-rx-0                                                      0          0      81398
23  70 eth2-tx-0                                                      3          3      33602
24  71 ether3                                                         0          0        923
25  72 eth3-rx-0                                                      1          1      63808
26  73 eth3-tx-0                                                      3          3        594
27  74 ether4                                                         1          1        839
[admin@MikroTik] >
Ripper
Sat Sep 24, 2011 10:17 pm
How to do that right
Chupaka
Sun Sep 25, 2011 1:09 pm
your NIC should support it. Intel 82574L has four queues, 82576 has eight queues...
about using the same IRQ by your both NICs - try to look at your BIOS settings...
nordex
Mon Sep 26, 2011 1:53 pm
After some time I can't login using winbox, it says connection refused.
Telnet is ok.
After reboot, everything is ok.
why?
Chupaka
Mon Sep 26, 2011 2:17 pm
and what if in Telnet you type
/ip services
disable winbox
enable winbox
honzam
Mon Sep 26, 2011 7:55 pm
RB SXT - 5.7. OSPF and no memory problem . Uptime 4days
hapi
Mon Sep 26, 2011 10:33 pm
how much you have routers in one area? We have about 100 routers and the more changes in, the SXT is more filled with memory.
I do not know what causes it. I assume that OSPF.
next SXT
nordex
Tue Sep 27, 2011 4:34 pm
/ip services
disable winbox
enable winbox
thanks for the tip.
I'll post the result next time it refuses the connection.
nordex
Wed Sep 28, 2011 12:05 am
Ok, today again I got connection refused from winbox, but
when I disabled/enabled it through telnet, it's ok again.
workaround is ok, but still this should be fixed. (or I'm the only one with this error ? )
hedele
Thu Sep 29, 2011 10:55 am
As a workaround, you might also consider using a scheduler to toggle the winbox service every hour or so.
Chupaka
Thu Sep 29, 2011 1:25 pm
just after WinBox service crashed, make supout.rif and send to support@mikrotik.com
alexspils
Thu Sep 29, 2011 4:03 pm
after upgrade from 5.6 to 5.7 in /ip service i see
# NAME PORT ADDRESS CERTIFICATE
0 telnet 23
1 ftp 21
2 www 80
3 I 22
4 X www-ssl 443 none
5 X api 8728
6 winbox 8291
security package wasn`t installed in 5.6
MikrotikNewbie
Thu Sep 29, 2011 4:41 pm
Thank you for the release of v.5.7
It sure would be great to get help with wireless timeouts when using nv2. I continue to get them with all the firmware versions I have tried. Connections can go for hours and even days with no errors and then I will get a wireless disconnect due to synchronization timeout. Occasionally I will also get media access errors ass well. Will new versions firrnware work to address these issues?
Ivoshiee
Thu Sep 29, 2011 5:23 pm
Your issue is not related to bridging, but to ethernet port flapping issue being speculated to be related to firmware issues:
http://forum.mikrotik.com/viewtopic.php?f=2&t=54038
Lakis
Forum Veteran
Forum Veteran
Thu Sep 29, 2011 9:55 pm
Finished testing for 5.7 waiting for 5.8:
Just tested one CPE to AP in lab.
- Connections hang in all modes (801.11/nstreme/nv2) when there is interference.
Connection is up but no traffic. After a while connection drops and comes back up.
Interference is generated by an ap 4m distance with 10db lower power without a cpe
connected. I'm not sure this is a wireless problem as the connection stays up for a while
while pings do not pass.
- ping suddenly did not work from CPE to AP. I have to enter source ip. Looking at
packets CPE has chosen the wrong (ethernet IP) to send packets over wlan1
- dhcp sometimes hog cpu
- Winbox crashes on win7
- CPE crashes and needs a power cycle
CPE is RB711-5Hn-MMCX, AP is RB411AH with R52nM chain1+2 enabled.
I've only done ping and bandwidth test between CPE and AP and change protocols
between 802.11,nstreme and nv2. Testing 20MHz Channel, 5GHz-A/N, no rate settings.
security profile wpa2 PSK. AP bridges between wlan1 and ether1.
After the CPE crash I stopped ...
May be someone at MT should do some testing. I dont think I've done extensive tests
to run into a lot of problems.
Dude something is wrong with ur hardware
JorgeAmaral
Trainer
Trainer
Fri Sep 30, 2011 3:48 am
/ip services
disable winbox
enable winbox
thanks for the tip.
This happens when your device is with low ram available, < 8MB.
NetworkPro
Sun Oct 02, 2011 3:40 pm
Nope. Happens more often than that. Router has 2GB RAM installed (x86).
I think this is a well-known bug for more then a year.
I think our Latvian friends are overwhelmed with working on new features, new products, a lot of incompatibility issues and strange bugs, that this one is very low priority.
It has always been my opinion that they should expand staff but paying good professionals will lower the owners riches so... ;)
nz_monkey
Mon Oct 03, 2011 11:18 am
I have to agree here, after getting a recent email from Mikrotik informing me that due to other priorities HWMP+ was not being actively maintained, and that they would not be able to investigate a repeatable problem that is a major issue for us (stale FDB entries when clients connect via wlan interfaces then roam) :(
heviejob
Tue Oct 04, 2011 9:34 am
My RB450G just upgraded from 5.6 to 5.7 .
It works fine, but the CPU usage get high in "dhcp" package.
Anyone has this?
We also have this problem. I already sent supout file to support but they say the cannot find anything ...
I have that problem also :( This is on a 450G board:
          cpu-used: 100
  cpu-used-per-cpu: 100%
       free-memory: 242784
Me too. 100% on dhcp. On 450G
NetworkPro
Tue Oct 04, 2011 9:45 am
Actually I have a couple of stable routers with 5.7 (450G and x86 P4 one core/thread). I guess its a hit and miss :( This is still not good enough though as I have a ton of other routers with tons of issues.
tlkhorses
Wed Oct 05, 2011 4:58 pm
Can't paste into a terminal brought up from webfig. Would be useful, used it all the time in winbox. Using OSX and Safari or Firefox, current versions.
tk
NetworkPro
Thu Oct 06, 2011 8:54 am
Please note that this happens not only when UPnP makes a NAT rule for the WinBox port, getting in the way of us connecting, but in cases when UPnP is not turned on as well.
adryfia
Fri Oct 07, 2011 4:50 am
I've tested 5.7 on rb750, the problem I found was too heavy cpu performance up to 100%, when I look at the /tool profile turned out to flash takes a lot of resources. And I return to 5.5 everything is running normally again.
NetworkPro
Fri Oct 07, 2011 6:18 am
Could it be you stumbled on a scheduled flash check or something else that is scheduled to run as a maintenance task?
MikroTik staff please clarify if such tasks are likely to cause 100% CPU.
tlkhorses
Sat Oct 08, 2011 2:02 am
On the cpu at 100%, in my case I use Zenoss to monitor the network. Zenoss re-models each device every 12 hours which uses snmp. At those intervals, I see 100% cpu warnings coming from the 5.7 ROS devices. I didn't see that in 4.17.
Lakis
Forum Veteran
Forum Veteran
Sun Oct 09, 2011 5:57 pm
When will be 5.8 I have ton of problems with RB1200
tenenbaum
Sun Oct 09, 2011 6:23 pm
Thank you for recent release and addressing a lot of issues we had with 5.6.
A few months ago I asked if it would be possible to add back the ability to sort by port in the Torch. Back then I thought I was all by myself but now if I search on port sort, I see a lot more people complaining about the loss of this function.
A lot of "strange" activity can't always be detected by a smart script or a config, which is why we also scan our network routers manually, especially when the maps report packet loss or unusual traffic.
THe ability to sort by port (both for src and dst) allows us to reveal viruses, aggressive and encrypted P2P, a stuck process that tries to go to Adobe, etc. etc.
Would it be possible to add this function back to the Winbox GUI?
What was the reasoning in taking it out?
oeyre
Mon Oct 10, 2011 4:02 am
What kind of problems?
tamahome
Tue Oct 11, 2011 3:09 pm
I have problems with the dns server. This is the second time this week that my Mikrotik RouterOS 5.7 Core DNS stopped responding.
I try ping google from console and I get IP DNS error or something like that. I reboot the rb1200 and works fine for a few more days.
This never happened to me with OS 5.6. I'm using google's dns (8.8.8.8 & 8.8.4.4).
Does anyone have any idea of what could be the problem?
Thank you.
NetworkPro
Tue Oct 11, 2011 3:18 pm
Google's DNS server itself had problems ?
When it happened to me I just put in another DNS server.
tamahome
Tue Oct 11, 2011 4:06 pm
I'm testing with my ISP DNS now, but if the DNS server is the problem shouldn't be solved by rebooting the rb1200.
WirelessRudy
Wed Oct 12, 2011 1:04 am
OH yes it can.
Your server stores dns resolves in a cache. If this was a piece of date coming from the google dns server you cache has the faulty data. When you reboot your router the cache gets flushed and new data needs to be used. If now this new data is ok the router works fine, for as long as it takes to get the wrong data from google again....
tamahome
Wed Oct 12, 2011 2:58 am
When I had the problem I tried flushing the dns cache in the rb1200. It gets empty and it doesn't take any more request so I continue without browsing...
ditonet
Forum Veteran
Forum Veteran
Wed Oct 12, 2011 10:00 am
From my experience there is a problem with ROS' built-in DNS resolver when cache size is set to value bigger than 8192 kB.
With different versions of ROS there was same problem, no response from DNS cache.
Also max. UDP packet size should be increased to value bigger than default 512 bytes (4096-8192).
HTH,
NetworkPro
Wed Oct 12, 2011 11:07 am
Why would the DNS packet be so big?
dbai
Wed Oct 12, 2011 1:49 pm
ROS v5.7 doesn't print and export IPv6 addresses of BGP peers:
/routing bgp peer print
Flags: X - disabled, E - established
 #   INSTANCE        REMOTE-ADDRESS                                 REMOTE-AS
 0   default         (unknown)                                      12345
There is the same problem with export. IPv6 adresess are always assigned as (unknown). WinBox shows IPv6 addresses correctly without any problems.
omega-00
Wed Oct 12, 2011 3:40 pm
Because to allow support for DNSSEC packet size allowed should be a minimum of 4096
The second issue is related to the packet size. The authors of the DNSSEC standard realized that there might be a potential problem with TCP queries. TCP puts a higher burden on the DNS servers. (TCP is much more expensive to process than UDP.) To avoid too much TCP traffic, the authors made the EDNS0 extension mandatory for DNSSEC. EDNS0 is a standard that among other things allows a client to signal that it is capable of receiving DNS replies over UDP that are larger than the previous limit of 512 bytes. Some firewalls are not aware of the fact that the EDNS0 standard allows for larger packets and they block any DNS packet larger than the previous limit. Other firewalls allow for the large packets by default, whereas a few vendors require the firewall to be manually configured to do so. Any device in the path that does packet inspection in the application layer must be aware of the EDNS0 standard to be able to make a correct decision whether to forward the packet or not.
Source: http://www.circleid.com/posts/operation ... ng_dnssec/
mecevdim
Wed Oct 12, 2011 7:19 pm
This happens on 4.x versions for OpenDNS servers 208.67.220.220 and 208.67.222.222 and for Google DNS servers too.
The particular routerboard for DNS resolving runs HotSpot and is a gateway for the network, ROS 4.17.
One thing I noticed is that you CAN ping the IP address, for ex.208.67.220.220 from the DNS resolver routerboard, but you CAN'T ping the same IP address from the inside of the network, for ex. from client who is authenticated on the HotSpot and Skype running, you get an answer from the DNS resolver routerboard: "destination host unreachable".
I've noticed this problem with earlier versions starting from 4.5 (don't sure for earlier versions) and only a reboot fixes it. Hope this will shred more light on this problem.
tamahome
Wed Oct 12, 2011 8:37 pm
So I should make a script that checks ping to google.com and reboot the router automatically or is there another way?
What is Mikrotik's opinion in this matter?
tamahome
Wed Oct 12, 2011 8:57 pm
The legend is: while reading ip address: could not get answer from dns server
I'm putting the dns cache back to 1024k, I had it at 10240k for more caching.
I'll let you guys know if it happends again.
janisk
Thu Oct 13, 2011 9:38 am
if you where running 5.7 maybe you could send supout.rif, in case we could find out more about the problem you encountered.
SXMU
Sun Oct 16, 2011 7:11 pm
ROS 5.7, firmware v. 2.36. I Have the problem - RB435G at random times(it may be one hour or one day) freezes ethernet interfaces to pass ip traffic, interface at that time says that "link ok"(i use 1G connection with different devices at different places, ~8 BOARDS with PC and board-to-board connections, most time of all its freezes at 2 RB435g's with bridge functions- wireless interface bridged with ethernet, not matter with which - ether1 or ether2 or ether3), wireless interface at the same time work properly and i can access the board via wireless, after rebooting board its' all right for a random time. A guess i have similar problem with the same topics - http://bugs.mikrotik-routeros.com/view.php?id=15, http://forum.mikrotik.com/viewtopic.php ... 1&start=50, http://forum.mikrotik.com/viewtopic.php ... 5G#p282149, http://forum.mikrotik.com/viewtopic.php?f=3&t=55610 etc.
Only one solution is to turn off or on /interface Ethernet switch set 0 switch_all_ports=yes or no, after that routerboard starts to transmit data. But i don't use hardware switch for boards, no master or slave interfaces, only program switch for bridging Ethernet iface with wireless, Don't know exact what the problem is, power supply is good, cables is good(at first time we think that the cables cat5e was caused the problem for 1G connection, and than replaced them to cat7 cables - have the same issue).
A hope for some assistance, it's not suitable to downgrade software or firmware on boards to avoid similar problems with configuration - a can't to stop transmission through that link cause they are situated on commercial towers and it's not real to get the boards directly.
Anyone suggest?
My opinion - it's a firmware trouble of RB435G at a side of Ethernet sensitivity, may be i'm wrong.
I hope the MTIK team to help.
NetworkPro
Sun Oct 16, 2011 7:17 pm
MikroTik gigabit ports have trouble from time to time.
RB450G different 5x versions different boards
RB250GS firmware 1.6
Auto-negotiation issues? Some sort of additional instability?
hobbit
Mon Oct 17, 2011 7:58 am
i have some troubles with this version:
on RB450G: high CPU usage (DHCP package) - i`m using vlans, so DHCP server is connected to vlan, not ethernet directly.
on all boards (and all 5x versions, i think):
- DNS package - when i remove static record, this one persist in memory until router is rebooted.
- Graphs: are completly deleted, when RB is rebooted.
so, i`m waiting for next version of RouterOS.
NetworkPro
Mon Oct 17, 2011 9:59 am
I love how MikroTik are improving on features like the Sniffer. The new filters are awesome.
My home RB450G was running 5.7 since it was released and just today it made me a problem (apart from DNS issues I thought were due to 8.8.8.8 being down)
The problem was that in Profile tool I could see sniffing making close to 100% CPU so I took a supout for support, rebooted, put in the latest unreleased 5.8 in the share subfolder and rebooted again.
Now testing with share 5.8 from the 12th.
Cheers.
ste
Mon Oct 17, 2011 10:06 am
Esp. saving to a file and then load the dump in wireshark is a great feature which helped a lot already.
Chupaka
Mon Oct 17, 2011 5:03 pm
huh, I love the Forum - you can learn many new things from users when you must learn it from developers =) Normis, please add it to the changelog? :)
normis
Tue Oct 18, 2011 8:37 am
do you see something that is not in the manual?
Chupaka
Tue Oct 18, 2011 11:35 am
argh, sorrrrry, overworking is killing my attention %(
NetworkPro
Tue Oct 18, 2011 12:40 pm
I am subscribed to WiKi pages but never receive e-mail notifications that hey were edited :)
mramos
Tue Oct 18, 2011 1:22 pm
Hi ...
I was running 5.7 on a RB433 + R52nM(PMP) + XR9(PTP) where the ETH is tied to an EOC1650 working as AP for 5 customers (sort of direct access with their laptops, tablets, etc). All natted, PMP & ETH have different IP ranges.
DHCP on ETH stop leasing from time to time (time seems equal to dhcp lease time, 24h in this case).
Was enough to wake it up back reboot the 1650 or disable / enable 433 eth (e.g. any change on ETH status).
Downgraded to 5.6 => no more problems.
Regards;
tamahome
Wed Oct 19, 2011 12:21 am
I'm still having DNS problems. The service DNS seems to stop working. In tools > profile, seems right but the DNS cache list gets empty and stop caching and resolving host.
The only way to fix it is rebooting the RB1200.
NetworkPro
Wed Oct 19, 2011 3:42 am
tamahome, did you try the latest 5.8 pre-release version ?
wispwest
Wed Oct 19, 2011 4:46 am
sorry if this has already been discussed, but does anyone know why wireless signal drops almost 10db when upgrading from 4.2? I have a PtP link I upgraded today, was at -61db, using 2x2 Mimo with SR71-15 cards. Signals on BOTH chains -60/-61, after the upgrade all the way to 5.7, AND bios update, the signals are now -74/-76 , I've checked and all the wireless settings are the same, nothing changed other than firmware update. what's the deal??????????? I've had this happen on 4 different PtP links now. I'm only upgrading cause I want NV2, but why such the sacrifice in signal?
dbai
Wed Oct 19, 2011 10:28 am
Where is possible to download these pre-release versions?
NetworkPro
Wed Oct 19, 2011 10:30 am
And what if you raise the tx power, does go back to normal?
pre-release version - tell MT support via e-mail what your issue is and they should give you the link
mecevdim
Wed Oct 19, 2011 11:28 am
NV2 is TDMA not OFDM and is good for PtMP links where you have a lot of noise, but for PtP links without a lot of noise just use nstreme. It has more throughput and less latency.
ste
Wed Oct 19, 2011 4:10 pm
Please check TDMA and OFDM with wikipedia.
NV2 is TDMA on top of OFDM and nv2 does not perform
better with noise. It performs better than nstreme where
there is no noice as it needs no polling. Instead it uses a
Map like wimax where the AP tells all CPEs at once when
to send. With noise I see 802.11 perform better then nstreme
and better then nv2.
wispwest
Wed Oct 19, 2011 4:29 pm
Wrong. NV2 has WAY more throughput than Nstreme, on 3 links already, that were short distance, 2X2, I was only able to get a steady 216x240Mbps. Turning on NV2 now its a rock-solid 300x300Mbps, and I can push almost twice the throughput on bandwidth tests, up to 210Mbps. Your right about latency though...
mecevdim
Wed Oct 19, 2011 6:00 pm
OK, this is my field experience. I use RB711 so single chain only, on a tower with a lot of Radio and TV stations, some of them with Mega Watts of power so I guess its a pretty "noisy" place . The PtP link is with Signal levels around -60dB, Noise level -110 dB ??? as reported from RB711, 13km perfect LOS, ROS 4.17 to 5.5 all the same. Tested on various frequencies range from 5000 to 6000 MHz.
-with Nstreme: Initially link is OK, data rates 150/150Mbps, CCQ 90-100%, Bandwidth test shows around 100Mbits UDP. The problem comes when real traffic is passed, around 20-30Mbits of traffic, CCQ starts to drop below 50%, data rates also drop below 54Mbps, ping goes high and that's about it. No more than 30Mbits throughput.
-with NV2: Initially the same conditions as with Nstreme, data rates 135/135 Mbps. When real traffic is passed, CCQ also drops but stays around 60-70%, data rates 81/108 Mbps and around 60Mbits total throughput.
So NV2 performs better then Nstreme in this kind of "noisy" situation. The question is WHY?
When I applied diplexers on both sides, with 100MHz channel, so say only 5700-5800 MHz range is passed, everything else is heavily attenuated, the same link is now working with Nstreme with 90% CCQ, data rates 121/135Mbits, 80Mbps throughput. I haven't change anything, all the same, Routerboards, pigtails, antennas, cables only difference are applied filters.
I don't know, maybe I'm missing something here but that's the results from real traffic not UDP Bandwidth test.
wispwest
Wed Oct 19, 2011 6:14 pm
One thing I have noticed, NV2 usually performs better on dual-chains, it seems running 2 chains creates some sort of self-interference with Nstreme, and sometimes I get worse data rates with 2 chains then single. However, activating NV2 makes 2 chains work together much better. My experience, single chain = Nstreme, Dual Chain = NV2.
tamahome
Thu Oct 20, 2011 1:46 pm
I have not tried 5.8pre, I'm still waiting for the final version to see if it is a bug.
franzinha
Sat Oct 22, 2011 11:54 am
I can confirm: as soon as you disable the interface used by dhcp-client, 'dhcp' process eats the whole CPU core until reboot
upd: after disabling dhcp-client, CPU goes down, just not momentarily
good morning everyone,
I own a 1100 with RB ros 5.7
The CPU is constantly at 100%, the profile indicates that the DHCP module is consuming 85%.
On the DHCP Client, it is installed but there is no interface added to it.
[xxxxx @ xxxxxx> ip dhcp-client print
# INTERFACE ADDRESS USE ADD STATUS
[xxxxx @ xxxxxx]>
DHCP logs are common.
franzinha
Sat Oct 22, 2011 12:01 pm
In my case, I have a RB in 1100 with 2 vlans DHCP and both are active.
Still, my CPU is constantly at 100% and in profile, the DHCP module is usndo 85% to 90% of the processing. :(
NetworkPro
Sat Oct 22, 2011 12:08 pm
Well test the 5.8 pre-release already?
DO NOT USE these unless you are prepared somehow to fix your network quickly as these may even brick your device - neither I nor anyone takes responsibility of what happens if you use these test versions
I have put them on many routers except powerpc and so far all 5.8 test versions worked without major issues but I still can not guarantee that your network will be just fine.
These files change from time to time - I download regularly and compare CRC32. When uploaded to a router you also see the date the package was put together.
http://www.mikrotik.com/download/share/ ... 86-5.8.npk
http://www.mikrotik.com/download/share/ ... pc-5.8.npk
http://www.mikrotik.com/download/share/ ... be-5.8.npk
http://www.mikrotik.com/download/share/ ... le-5.8.npk
If you use User-Manager package DO NOT UPGRADE as you will need that package as well - ask support for 5.8 version of it for the platform(s) you use
If you notice any issues - get supout.rif from router and maybe a screenshot and send to support.
FStorm
Sat Oct 22, 2011 3:05 pm
Will there be implemented in the new version of the chipset support Intel H61?
NetworkPro
Sat Oct 22, 2011 3:25 pm
It should work already? Have you encountered any problem when testing?
FStorm
Sat Oct 22, 2011 4:50 pm
Mikrotik version 5.7 installed on this hardware:
Processor: Intel Core i5-2300
Motherboard: Asus P8H61 (Chipset Intel H61)
Network card: Intel PRO 1000GT Desktop Adapter
The system motherboard chipset is defined as "Unknown device", and the amount of traffic is limited to 200-210 Mbps.
If we use the following hardware:
Processor: Intel Core 2 Duo E6750
Motherboard: Asus P5KC (Chipset Intel P35)
The system chipset motherboard reports the correct
Productivity rises to the level of 290-300 Mbps, which in my case is the correct figure
P.S. Spoken English I know little, because I apologize for the quality of texts.
NetworkPro
Sat Oct 22, 2011 9:02 pm
Could be on the slower board the LAN card is connected to PCI bus and the faster - on PCI-e bus.
If you are running windows on the slower board - post a screenshot of Device Manager but viewed by Connection so we see to what the NIC/LAN card is connected.
(don't forget to give karma :D but I have a paypal account as well :D)
FStorm
Sat Oct 22, 2011 9:54 pm
On both motherboards are the same network cards are placed in the slot PCI 2.0
Screenshots do not yet possible
SXMU
Tue Oct 25, 2011 8:27 am
Continue of ethernet flapping interface problem /sorry for copypasting the thread, have no time/ :
Same trouble with http://www.mikrotik.com/download/share/ ... be-5.8.npk, ethernet freezes after 1 day of work, downgrading ROS to 4.17 have solve this problem.
ROS 5.7, firmware v. 2.36. I Have the problem - RB435G at random times(it may be one hour or one day) freezes ethernet interfaces to pass ip traffic, interface at that time says that "link ok"(i use 1G connection with different devices at different places, ~8 BOARDS with PC and board-to-board connections, most time of all its freezes at 2 RB435g's with bridge functions- wireless interface bridged with ethernet, not matter with which - ether1 or ether2 or ether3), wireless interface at the same time work properly and i can access the board via wireless, after rebooting board its' all right for a random time. A guess i have similar problem with the same topics - http://bugs.mikrotik-routeros.com/view.php?id=15, viewtopic.php?f=1&t=55021&start=50, viewtopic.php?f=0&t=55021&p=282149&hilit=435G#p282149, viewtopic.php?f=3&t=55610 etc.
Anyone suggest?
NetworkPro
Tue Oct 25, 2011 8:37 am
What exactly is the other device, switch that is connected to the ports that stop working?
When problem happens, can you send supout to support?
I had similar issues as well, with RB250GS, RB450G (died), RB750 but with different software versions.
SXMU
Tue Oct 25, 2011 10:29 am
It's not matter what device connected on other side, in my case - PC with Intel Gb adapter, RB450G, or other RB435G board, but most of all it's freezes at a stack of 2 RB435G's - one time on first board, next time on second in random time.
I just forgot to send supout because i immediately had downgrade all RB's to 4.17 and enable nv2-wireless package. unfortunately, 4.17 does not achieve that speed throught wireless as 5.3 and higher versions of ROS ((.
NetworkPro
Tue Oct 25, 2011 10:50 am
What if you tweak the Ethernet auto-negotiation options?
SXMU
Tue Oct 25, 2011 3:41 pm
1G connection seems to be work only on auto-negotiation.
Other thing - 433AH boards on 100M FD works fine at ROS 5.5 at the same tower, troubles probing only at 1G connections.
Any suggest?
docmarius
Wed Oct 26, 2011 10:21 pm
I want to signal a strange issue, not 100% that it is related to this firmware (i can not identify the exact moment in time when it happened, but it seems synchronized to the upgrade).
HW: Routerboard 450G, setup as NAT + PPPoE
I updated from 4.17 to 5.7 one month or so ago. And i saw a steep drop in performance and blamed it on the ISP (from 90Mb/s to 2.5Mb/s).
In the last days i tried to find the cause since my ISP stated it is all ok. Checking the direct link gave me 45Mb/s, so the provider had nothing to do with it.
When checking System -> Resources in Winbox, the CPU frequency got somehow set to 100MHz instead of 680MHz (i didn't do it on purpose since i didn;t know about that option :lol: ).
Changing the value back to 680MHz (System->Routerboard->Settings) gave me a peak NAT performance of 190Mb/s.
If someone complains of low speed, this parameter could be worth a look.
Greetings,
"Doc" Marius
alexspils
Thu Oct 27, 2011 12:05 pm
i have problem in one of my x86 routers: it stops routing. It can be pingable, it can ping others routers, i can connect to it, reboot fix problem. Last time it happened i was unable create supout file beacause i have to fix it quickly. If it happens again i will create supout file.
# NAME VERSION SCHEDULED
0 system 5.7
1 ntp 5.7
2 dhcp 5.7
3 advanced-tools 5.7
4 routing 5.7
NetworkPro
Thu Oct 27, 2011 12:26 pm
Can you please post a /ip routing export and /ip route export Thanks.
elgo
Thu Oct 27, 2011 12:53 pm
This exactly happened to me right yesterday with rOS v5.6 on 450G.
I checked Interfaces IP addresses and routes, all seemed OK. DHCP server on the router wasn't answering either.
I generated a supout before rebooting unit, I'll send it to support.
Jeeves
Thu Oct 27, 2011 3:04 pm
:( No dhcpv6...
http://wiki.mikrotik.com/wiki/Manual:IPv6/Pool
'Secretly' downloaded 5.8 and I managed to get DHCPv6 working. Cool.
Jeeves
Thu Oct 27, 2011 3:21 pm
Chupaka
Thu Oct 27, 2011 3:34 pm
docmarius
Fri Oct 28, 2011 12:06 am
What about DHCPv6 client and receiving prefix delegation via DHCP client?
janisk
Fri Oct 28, 2011 9:11 am
exactly that - you will be able to receive prefix using '/ip dhcp-client' that is in "secret 5.8" already.
docmarius
Fri Oct 28, 2011 10:43 am
Nice. Just checked it...
The only part missing now is to do this on a PPP(oE) interface...
nz_monkey
Fri Oct 28, 2011 1:03 pm
When will "secret 5.8" be out ?
It will be good to finally have DHCPv6-PD !
NetworkPro
Fri Oct 28, 2011 3:13 pm
I hope it will be release totally totally REALLY completely 101% stable. I can wait.
JorgeAmaral
Trainer
Trainer
Fri Oct 28, 2011 4:22 pm
+1
sadeghrafie
Long time Member
Long time Member
Fri Oct 28, 2011 6:58 pm
I hope in new release the report problem in the user manager will be fix, I hope :)
Jeeves
Sat Oct 29, 2011 9:40 pm
Is it correct that I cannot do DHCPv6 and Radius?
jandafields
Sat Oct 29, 2011 10:02 pm
Did someone say that it couldn't be done? The DHCP Server (4 and 6) has a checkbox for "USE RADIUS". Also, the Radius config window allows you to enter an IPv4 or an IPv6 address for a remote radius sever.
Jeeves
Sat Oct 29, 2011 10:51 pm
I now, and I've seen that. But I do not see any requests on Radius when doing DHCPv6. So it might not be implemented yet.
engineertote
Sun Oct 30, 2011 1:33 pm
Cheers.
can you tell me how u do sniffer filter pls ,, as i facing issue that my PPP server its been attacked by cain program that its using MAC sniffer.
Regards
docmarius
Sun Oct 30, 2011 3:32 pm
Any plans of implementing PPPv6 + PD also?
Users browsing this forum: No registered users and 152 guests
