Tue Sep 27, 2011 11:05 pm
The RFC allows use of TCP, so surely the choice of protocol should be the user's? I have a problem, as currently implemented MikroTik RADIUS Client is unstable, if TCP were available I could at least test whether using it would solve my problem.
I'm left with two choices, either live with something that has intermittent problems or replace MikroTik routers at affected sites with something more generic that correctly implements the RFCs and gives me the choice.
Can MikroTik not give us the choice whether to use TCP or UDP, this would seem a very simple change to make to software that performs pretty well under most circumstances, more stable in marginal conditions? Anyone can make devices work in ideal conditions, what separates the great hardware from the average is when it performs equally (or almost so) under adverse conditions.
Regards
Chris Macneill
