Code: Select all
http://www.foxconnchannel.com/product/Motherboards/detail_spec.aspx?ID=en-us0000511
thank you
Just add a supported PCI or USB network card to your motherboard, problem fixed!this means i have to wait for new kernel update for mikrotik? it is hard to believe atheros interface is not recognized, as most networking interface especially wireless and switch chip came from atheros.
#1 USB network adapterPCI maxed out
http://www.mikrotik.co.id/produk_lihat.php?id=221
nope, would support help? or i'll just get the same answer as what normis said.have you written to support@?
New kernel is in RouterOS v6. Have you tried that?i know it's been 5 months, but this device still unrecognized. i have updated it to v5.15 ROS. is there somewhere else i can request this?
