The SSTP in Mikrotik uses the built-in Windows Vista/7 (NO XP SUPPORT) SSTP client. You have to set it up in Windows as a new virtual/vpn network connection. There is no web-based SSTP in Mikrotik.I'm wanting to setup my box with a web based login page for sstp so users can just goto a url (ie. vpn.mycompany.com) and be presented with a login page kinda like the Hotspot services has... Is it possible? Can anybody help me?
NO. You cannot "install" anything on the Mikrotik (unless you do meta-router, which is an entirely different subject). Anything beyond the basic included functionality requires a separate product like OpenVPN Access Server. The ONLY web-based network authentication that Mikrotik has is the hotspot.Can I install OpenVPN on my mikrotik box AND have it display a web page where a users is promped for un/pw it then creates an ssl/vpn connection? ie not insalling anything on the client or configuring the client in anyway....
My goal is so somebody can goto a public computer browse to the url, login and then there connected with the internal network. If possible all with the Mikrotik itself.
If anybody has any guides I'd love it.
