I'm testing RB433GL with Compex(WLM200N5-23, 2X2 mimo) and UNEX(DNMA-H5 3X3 mimo). My PCs have Gigabit ethernet port.
I set - AP-Bridge mode - 5GHz-A/N - 20/40MHz HT Ablove - 5200MHz - HT Tx chain: Chain0, Chain1 - HT Rx chain: Chain0, Chain1 - HT Guard Interval: any - WDS mode: dynamic mesh - other things are all factory default parameter.
below capture, you can see 20/40MHz as I set.
But below capture, scanned result is only 20MHz.
Throughput test is only around 20Mbps. I wish more then 200Mbps at indoor. I bet, in our test room, there is no 5GHz device and other 5GHz wireless device is more then 200Mbps.
I wish to get answer any of you. And strongly wish to get answer from mikrotik.
Lower Tx Power (u should have around -45 to -55dBm) Then set AP and Client: HT Guard Interval to long HT Extension Channel to Above Control Select all 7 Options under HT AMPDU Priorities
What it mean " HT Extension Channel to Above Control" I don't know how it control
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot post attachments in this forum
