We are using an extra linux box with custom configuration as aggregators to achieve bonding of different medias with asymmetric and nonmatching bandwiths. For example we are bonding a cable modem using ethernet 15/1,5 and a DSL connection 8/2 into a single connection roughly 23/3,5 that you see 22-23/3-3,5 if you do bandwith test.
I was wondering if Mikrotik has, or will have support for that type of bonding. For example I create 2 different gre tunnels to a remote destination using different connections, and Mikrotik bonds these tunnels into one single connection?
Thanks!
