Many thankstry to change the download url, where is written the actual version, change it
with the version you want to download. For example in the download url where
is written 5.14 change it to 5.9
Point taken but not sure about ...even on the forum you won't get any real assistance there is a lot users on the forum who try to helpif you don't use v5.14 (or whatever is the latest), you will not get any support and even on the forum you won't get any real assistance. We release versions for a good reason.
What is wrong with the current NTP package?I tired to get 5.11 so I could just get NTP but Mikrotik seems to have locked out access to the older versions
Does this feature work like a boot loader where you can deside which partition to boot from?You can now use the new Partitioning feature. Upgrade only a test partition, if it fails, fallback to your main partition.
When you mark a partition as active, the next time that router reboots, it will boot on the marked partition as active.Does this feature work like a boot loader where you can deside which partition to boot from?
yes, you can also select your partition from the RouterBOOT menuDoes this feature work like a boot loader where you can deside which partition to boot from?You can now use the new Partitioning feature. Upgrade only a test partition, if it fails, fallback to your main partition.
Thank you - that worked?have you tried http://www.mikrotik.com/download/router ... 20.torrent
